Adapter 4Pin (12V) to 3Pin (7V)
  • 81002
  • 4260048810405
  • 0,026 kg
€1.19 * €2.09 * (43.06% Saved)
For connecting a fan with a 3-pin Molex connector (CPU cooler, case fan, etc.) to a power supply... more
For connecting a fan with a 3-pin Molex connector (CPU cooler, case fan, etc.) to a power supply connector (4-pin). The adapter allows the fan to operate at 7 volts instead of 12 volts, which reduces noise. Please note that this reduces the rotation speed of the fan and therefore the air flow rate.
Important note: Please note that older power supplies without overload protection may be damaged if the adapter is loaded with more than 500mA.
Hersteller: Aquatuning
1st page: 1x 4Pin
2nd page: 1x 3Pin
Design: Adapter
Sleeving: Without
Alphacool Y-Splitter 3-Pin to 2x 3-Pin 15cm
Content 15 Zentimeter (€10.60 * / 100 Zentimeter)
€1.59 * €2.28 *
LK Alphacool Y-Splitter 3-Pin auf 2x 3-Pin 60cm
Alphacool Y-Splitter 3-Pin to 2x 3-Pin 60cm
Content 60 Zentimeter (€3.13 * / 100 Zentimeter)
€1.88 * €2.68 *
Alphacool Y-splitter 3-Pin to 3x 3-Pin 60cm
Content 60 Zentimeter (€4.63 * / 100 Zentimeter)
€2.78 * €3.97 *
Alphacool Y-Splitter 3-Pin to 4x 3-Pin 15cm
Content 15 Zentimeter (€13.93 * / 100 Zentimeter)
€2.09 * €2.98 *
LK Adapter 3Pin (12V) auf 4Pin Molex (12V)
€1.79 *
€2.09 * €2.98 *
Alphacool Y-Splitter 3-Pin to 3x 3-Pin 15cm
Content 15 Zentimeter (€11.60 * / 100 Zentimeter)
€1.74 * €2.48 *
Alphacool Y-Splitter 4-Pin to 3x 4-Pin PWM 15cm
Content 15 Zentimeter (€13.00 * / 100 Zentimeter)
€1.95 * €2.78 *
54%
Alphacool RGB 4-pin LED adapter cable for motherboards - Black 50cm
Content 50 Zentimeter (€3.96 * / 100 Zentimeter)
€1.98 * €4.28 *
SZ Schlauchklemme bis 15mm
hose clamp up to 15mm
€5.49 *
Alphacool Y-Splitter 4-Pin to 3x 4-Pin PWM 15cm white
Content 15 Zentimeter (€14.87 * / 100 Zentimeter)
€2.23 * €3.18 *
€99.98 *
33%
LK Alphacool Y-Splitter 3-Pin auf 4x 3-Pin 60cm
Alphacool Y-Splitter 3-Pin to 4x 3-Pin 60cm
Content 60 Zentimeter (€5.00 * / 100 Zentimeter)
€3.00 * €4.47 *
Alphacool Y-Splitter 4-Pin to 4x 4-Pin PWM 30cm
Content 30 Zentimeter (€9.97 * / 100 Zentimeter)
€2.99 * €4.28 *
Alphacool Y-Splitter 4-Pin to 2x 4-Pin PWM 30cm
Content 30 Zentimeter (€6.27 * / 100 Zentimeter)
€1.88 * €2.68 *
€1.88 * €2.68 *
Content 24 Stück (€0.29 * / 1 Stück)
€6.99 *
Alphacool EPDM Tube 16/10 - Black 3m (9.84ft) Retailbox
