Phobya Verlängerung 3Pin Molex ultra lang - Schwarz 90cm
  • LK
  • 4049469160883
  • 0,015 kg
€5.48 *
Content: 90 Zentimeter (€6.09 * / 100 Zentimeter)
Extension cable for 3-Pin cables e.g. for fans. With rpm signal lead. Sleeving: This cable... more
Sleeving:
Sets:
Technical specifications:
Connectors: 3-Pin extension
Black sleeve, black connectors and black heatshrink
Length: 90cm
Conforms with RoHS
Extent of delivery:
1x Phobya extension cable 3-Pin Molex 90cm - black
This product has been reviewed for you:
Aquainfos
Tech-Review
Hersteller: Phobya
2. Seite: 1x 3Pin
Sleeving: schwarz
1. Seite: 1x 3Pin
Bauform: Verlängerung
Hint!
LK Phobya Verlängerung 3Pin - Schwarz 30cm EOL
Content 30 Zentimeter (€10.60 * / 100 Zentimeter)
€3.18 *
€5.68 *
Hint!
LK Phobya Y-Kabel 3Pin Molex auf 9x 3Pin Molex -  Schwarz 60cm EOL
LK Phobya Adapter 3Pin (12V) auf 3Pin (7V) - Schwarz 20cm
Content 20 Zentimeter (€17.40 * / 100 Zentimeter)
€3.48 *
Hint!
€3.18 *
LK Phobya Y-Kabel 3Pin Molex auf 2x 3Pin Molex - Schwarz 30cm
Content 30 Zentimeter (€11.60 * / 100 Zentimeter)
€3.48 *
Content 4 Gramm (€3,995.00 * / 1000 Gramm)
SEN Alphacool Eiszapfen Temperatursensor flach G1/4 - chrom
Alphacool Eiszapfen temperature sensor flat G1/4 - chrom
Hint!
LZ Phobya 4Pin Molex auf 9x 3Pin Splitter EOL
€4.04 *
ZK Phobya 2pin-Kabel Verlängerung Buchse/Stecker 60cm - Schwarz
Content 60 Zentimeter (€7.47 * / 100 Zentimeter)
€4.48 *
Hint!
LK Phobya Verlängerung 3Pin Molex extra lang -  Schwarz 60cm EOL
€4.48 *
Alphacool Core Thermal Pad Soft 9W/mk 40x40x2mm
Content 16 cm² (€0.62 * / 1 cm²)
Alphacool Core Thermal Pad Soft 9W/mk 40x40x1,5mm
Content 16 cm² (€0.50 * / 1 cm²)
Content 100 cm² (€0.37 * / 1 cm²)
€36.99 *
Alphacool y-splitter 3-Pin to 3x 3-Pin 30cm
Content 30 Zentimeter (€16.60 * / 100 Zentimeter)
€4.98 *
Alphacool Eiszapfen angled adaptor 90° rotatable G1/4 AG to G1/4 IG - 4pcs Set Deep Black
Content 4 Stück (€7.25 * / 1 Stück)
€28.98 *
WAK Alphacool Eisblock Aurora GPX-N Acryl Active Backplate 3080/3090 Suprim X EOL
€49.98 * €86.98 *
SEN Alphacool Eiszapfen Temperatursensor flach G1/4 - schwarz
Alphacool Eiszapfen temperature sensor flat G1/4 - Black
WAK Alphacool Eisblock Aurora Acryl GPX-A RX 6700XT Gaming X mit Backplate EOL
Alphacool Eisblock Aurora Acryl GPX-A RX 6700XT Gaming X with Backplate
€79.99 * €149.98 *
Alphacool Apex Soft Thermal Pad 11W/mk 100x100x1mm
Content 100 cm² (€0.36 * / 1 cm²)
RAD Alphacool NexXxoS ST20 HPE Full Copper 120mm Radiator
Alphacool NexXxoS HPE-20 Full Copper 120mm Radiator
€55.98 *
€44.98 *
WAK Alphacool Eisblock Aurora Acryl GPX-N RTX 3090/3080 Suprim X mit Backplate
Alphacool Eisblock Aurora Acryl GPX-N RTX 3090/3080 Suprim X with Backplate
€89.99 * €149.99 *
€2.98 *
Alphacool Universal feet for radiators
Content 2 Stück (€12.49 * / 1 Stück)
€24.98 *
Alphacool Tubing AlphaTube HF 19/13 (1/2"ID) - Ultra Clear 3m (9,8ft) "Retail Package"
Content 300 Zentimeter (€7.99 * / 100 Zentimeter)
€23.98 *
Alphacool Twin LED RGB 30cm - Sleeving black
€5.48 *
RAD Alphacool NexXxoS XT45 Full Copper 420mm Radiator V.2 PHT EOL
Alphacool NexXxoS XT45 Full Copper 420mm radiator V.2
€109.98 * €124.99 *
KOE Alphacool Eiswand 360 Ersatzbehälter - Nylon
Alphacool Eiswand 360 replacement reservoir - Nylon
€9.28 *
Alphacool powerbutton/switch connection cable 200cm - black
Content 200 Zentimeter (€3.24 * / 100 Zentimeter)
€6.48 *
