Phobya 2pin-Kabel Verlängerung Buchse/Stecker 60cm - Schwarz
- Article no.: ZK
- EAN: 4049469161286
- Weight: 0,009 kg
This 2-Pin extension cable can be sued for sensors which are too far away from the monitoring device. Especially in larger cases or when attempting cable management out of sight these extension come in very hand.
Of course this cable can also be used for many more applications such as the case speakers or power- or reset-button.
Sleeving:
Technical specifications:
Connectors: 2-Pin to 2-Pin extension
Colour: Black
Length: 60cm
Conforms with RoHS
Extent of delivery:
1x Phobya 2pin-cable extension plug/socket 60cm black
