Alphacool Eiszapfen temperature sensor plug G1/4 - Chrome
  • 17364
  • 4250197173643
  • 0,025 kg
Alphacool icicle temperature sensor A sensor that is simply screwed into a G1/4" thread.... more
A sensor that is simply screwed into a G1/4" thread. With cable and 2-pin connection.
Can be used in all exposed G1/4" threaded openings on the radiator, expansion tank or in a T-piece that is integrated in the circuit.
Fully encapsulated and therefore completely sealed. Thanks to nickel plating - no corrosion problems! Full functionality with any PC temperature indicator that is compatible with standard PC temperature indicators! Control your PC INDEPENDENTLY of the BIOS sensors: This is double protection, similar to the well-known "redundancy" (double security) in the professional sector."
Long (50cm) connection cable, also suitable for big towers!
Scope of delivery
  • 1x Alphacool Eiszapfen temperature sensor plug G1/4 - Chrome
It is a 10kOhm temperature sensor that is compatible with the following devices, among others:
  • aquaero 3.07, aquaero 4.00
  • aquastream XT Ultra
  • aquaduct variants with external sensor input (360 XT, 720 XT)
  • Alphacool Heatmaster
  • Innovatek Fan-O-Matic
  • Lian Li Multipanel
  • Scythe Kaze
  • T-Balancer
RT Sensor Table: Open the PDF
  • Sensor inputs of many motherboards
€1.79 *
6%
€16.98 * €17.98 *
