Phobya 2pin-Kabel Verlängerung Buchse/Stecker 30cm - Schwarz
ZK Phobya 2pin-Kabel Verlängerung Buchse/Stecker 30cm - Schwarz
  • ZK
  • 4049469161279
  • 0,005 kg
€4.48 *
This 2-Pin extension cable can be sued for sensors which are too far away from the monitoring... more
This 2-Pin extension cable can be sued for sensors which are too far away from the monitoring device. Especially in larger cases or when attempting cable management out of sight these extension come in very hand.
Of course this cable can also be used for many more applications such as the case speakers or power- or reset-button.
Sleeving:
Technical specifications:
Connectors: 2-Pin to 2-Pin extension
Colour: Black
Length: 30cm
Conforms with RoHS
Extent of delivery:
1x Phobya 2pin-cable extension plug/socket 30cm black
ZK Phobya 2pin-Kabel Verlängerung Buchse/Stecker - 30cm
€4.48 *
L12 Alphacool Core 120mm Lüfter PWM 3000rpm (120x120x25mm)
Alphacool Core 120mm fan PWM 3000rpm (120x120x25mm)
€8.48 *
ANF Alphacool ES D-Plug 20mm G1/4 AG auf G1/4 AG - Chrome
€7.28 *
KOI Alphacool Eisbaer Pro Aurora 280 CPU AIO
€194.98 *
Alphacool Twin LED RGB 30cm - Sleeving black
€5.48 *
ZSO Alphacool Eiskoffer - Multi-Biegeanleger klein
Alphacool Eiskoffer - Multi-Mandrel - small
€24.98 *
KAB Alphacool Y-Kabel RGB 4pol auf 3x 4pol inkl. Stecker - Schwarz 30cm
Alphacool y-cable RGB 4pol to 3x 4pol 30cm incl. connector - black
Content 30 Zentimeter (€8.27 * / 100 Zentimeter)
€2.48 * €6.49 *
Alphacool GPU RAM Copper Heatsinks 14x14mm - 10pcs
SEN Alphacool Eiszapfen Überdruckventil G1/4 - Deep Black
Alphacool Eiszapfen Pressure Valve G1/4 - deep black
WAR Alphacool D-RAM Cooler X4 Universal - Acetal Black Nickel
€54.98 *
WZS Alphacool Rückschlagventil G1/4 IG - Deep Black
Alphacool check valve G1/4 IG - Deep black
€11.98 *
Alphacool tubing AlphaTube HF 13/10 (3/8"ID) - clear
RAD Alphacool NexXxoS XT45 Full Copper 560mm Radiator
Alphacool NexXxoS XT45 Full Copper 560mm radiator
€149.98 *
ZK Phobya Fan Power Connector 2Pin Stecker - 4 Stück Black EOL
€1.00 *
WÄM Alphacool Wärmeleitklebepad doppelseitig 120x20x0,5mm
Alphacool double-sided adhesive pad 120x20x0,5mm
Content 24 cm² (€0.12 * / 1 cm²)
€2.98 *
€3.98 *
LZ Lüftergitter für Axiallüfter für 92mm schwarz
Fan grill for axial fans for 92mm black
€1.79 *
