Alphacool Core Geforce RTX 4090 Suprim with Backplate
- Article no.: 13475
- EAN: 4250197134750
- Weight: 2,131 kg
- MSI GeForce RTX 4090 Gaming Trio 24G, 24GB GDDR6X
- MSI GeForce RTX 4090 Gaming X Trio 24G, 24GB GDDR6X (V510-006R)
- MSI GeForce RTX 4090 Suprim Liquid X 24G, 24GB GDDR6X
- MSI GeForce RTX 4090 Suprim X 24G, 24GB GDDR6X (V510-001R)
Technical data cooler | |
Dimensions (L x W x H) | 269,37 x 153,75 x 32,85mm |
Threads | 4 x G1/4" |
Thickness cooler bottom | 11,3mm |
Illumination | digital aRGB LEDs |
Number of digital aRGB LEDs | 16 |
Color | transparent |
Technical data backplate | |
Dimensions (L x W x H) | 269,37 x 130,75 x 5mm |
Material | aluminium |
Color | black |
Material Bodenplatte: | Kupfer; |
Material Deckel: | Acryl; |
SLI kompatibel: | Ja |
Kühlertyp: | Komplettkühler |
Hinweis: | Kompatibel bis 16/13mm gerade;Kompatibel bis 19/13mm gewinkelt; |
Anschluss: | 4x G1/4" |
Hardware Modell: | RTX 4090; |
Abmessungen: | 269,37 x 153,75 x 32,85mm |
Liefertermin: in 7 - 8 Wochen
