Alphacool Core Geforce RTX 4090 Suprim with backplate
- Article no.: 13475
- EAN: 4250197134750
- Weight: 2,131 kg
- MSI GeForce RTX 4090 Gaming Trio 24G, 24GB GDDR6X
- MSI GeForce RTX 4090 Gaming X Trio 24G, 24GB GDDR6X (V510-006R)
- MSI GeForce RTX 4090 Suprim Liquid X 24G, 24GB GDDR6X
- MSI GeForce RTX 4090 Suprim X 24G, 24GB GDDR6X (V510-001R)
| Technical data cooler | |
| Dimensions (L x W x H) | 269,37 x 153,75 x 32,85mm |
| Pressure tested | 0,8 bar |
| Threads | 4 x G1/4" |
| Thickness cooler bottom | 11,3mm |
| Number of digital aRGB LEDs | 16 |
| Color | transparent |
| Dimensions (L x W x H) | 269,37 x 130,75 x 5mm |
| Material | aluminium |
| Color | black |
| Hersteller: | Alphacool |
| Cooler type: | Complete cooler |
| Material base plate: | Copper; |
| Material Lid: | Acrylic; |
| SLI compatible: | Yes |
| Dimensions: | 269,37 x 153,75 x 32,85mm |
| Connection: | 4x G1/4" |
| Hardware manufacturers: | NVIDIA |
| Hardware model: | RTX 4090; |
| Notice: | Compatible up to 16/13mm straight; Compatible up to 19/13mm angled; |
