Alphacool Eisblock Aurora Acrylic GPX-N RTX 3090 Founders Edition with Backplate
  • 11941
  • 4250197119412
  • 1,482 kg
€73.98 * €159.97 * (53.75% Saved)
€17.98*
ANZ Alphacool Eiszapfen screw plug V.2 G1/4 - Deep Black
€3.29*
€35.98*
€17.98*
€6.49*
The Alphacool Eisblock Aurora Acryl GPX-N RTX 3090 FE combines style with performance and... more
The Alphacool Eisblock Aurora Acryl GPX-N RTX 3090 FE combines style with performance and extensive digital RGB lighting. Over 17 years of experience have been incorporated into this graphics card water cooler and represent the current pinnacle of Alphacool product development.
More performance!
When developing the Eisblock Aurora GPX-N RTX 3090 FE graphics card water cooler, emphasis was naturally placed on increasing performance. In the first step, the cooler was brought closer to the individual components by reducing the thermal pads to a thickness of 1 mm. In the second step, the nickel-plated copper block was also made thinner. Instead of the previous 7 mm, it is now only 5.5 mm thick. The water flow within the cooler has also been optimized. All important components such as the voltage converters and the RAM are now cooled much better and more effectively by the water. All of this ensures a significant increase in cooling performance.
New design!
The Eisblock Aurora GPX-N RTX 3090 FE cooler was fundamentally designed in such a way that the lighting is more in the foreground than in previous models. The addressable digital RGB LEDs are embedded directly in the cooling block and they run along the sides of the entire cooling block. The effect is lighting that encloses the entire cooling block. No corner or edge remains unlit by the aRGB LEDs. The new design is more angular, with all edges bevelled. The result is better light scattering in the water cooler due to the reflections on these bevels. They also create various contours that give the Eisblock Aurora GPX-N RTX 3090 FE cooler a very unique visual touch.
Copper or aluminum?
Alphacool naturally only uses copper in its water coolers. The Eisblock Aurora GPX-N RTX 3090 FE has nickel-plated copper. Compared to previous models, however, Alphacool has further improved the type of nickel plating, which has significantly increased acid resistance. This should prevent nickel plating from flaking off. And why does Alphacool use copper instead of aluminum? Copper simply has almost twice the thermal conductivity of aluminum and is therefore clearly the better material for water cooling.
Are these all the new things?
The Eisblock Aurora GPX-N RTX 3090 FE graphics card water cooler also uses the new patented locking screws, which are flush with the surface of the terminal. The Alphacool logo is now in the corner on the top and is also fully illuminated. The corresponding designations of the compatible graphics card types can be seen on the front of the terminal. Of course, these are also fully illuminated by the digital LEDs. IN and OUT are now marked by small, discreet triangles. They are easily recognizable and fit perfectly into the overall visual line of the graphics card water cooler.
The Alphacool Aurora GPX-N RTX 3090 FE Acryl is in every respect a complete development of the previous Alphacool graphics card water coolers. No technical compromises were made, but the entire technical know-how was incorporated into the development and implementation.
Note:
- This cooler comes with a backplate!
- The Founders Edition does NOT correspond to the Reference Design!
Technical data:
L x H x W: 120.7 x 231.5 x 29.2 mm
Cooler material: Nickel-plated copper
Lid material: acrylic
Thickness of cooling fins: 0.6 mm
Connections: 4x G1/4“
Digital RGB power connector: 3-pin 5V (0.5A)
Graphics card configurator: Click here!
Compatibility list: Nvidia cards
Compatibility list:
- NVIDIA GeForce RTX 3090
Download manual PDF: Alphacool Eisblock Aurora Acryl GPX-N RTX 3090 FE with Backplate
Download data sheet PDF: Alphacool Eisblock Aurora Acryl GPX-N RTX 3090 FE with Backplate
Cooler type: Complete cooler
Material base plate: Copper;
Material Lid: Acrylic;
SLI compatible: Yes
Dimensions: 231,5 x 120,7 x 29,2mm
Connection: 4x G1/4"
Hardware model: RTX 3090;
SZ Schlauchabschneider
hose cutter
€6.29 *
€38.98 *
Content 6 Stück (€5.00 * / 1 Stück)
€29.98 *
€99.98 *
€6.49 * €8.98 *
