Alphacool NexXxoS Monsta 180mm Single radiator
  • 14213
  • 4250197142137
  • 1,817 kg
€122.98 *
Versatility is the essence of the new NexXxos series! The radiators are designed to be used with 120mm as well as 140mm fans and are available in different thicknesses. The choice of 30mm, 45mm and 60mm offers the perfect radiator for every purpose. Even mounting and installation of fans and radiator grills is easy and versatile with these radiators: The M3 threads are standard in the radiator sector and available in all lengths at an affordable price.
Dimensions (L x W x H)225 x 182 x 85mm
Cooling channelsCopper
Fan threadM3
Number of fans1
Connection6x G1/4"
SlatsCopper
Thickness69 - 100mm
HousingSteel
ManufacturerAlphacool
Pressure tested0,8 bar
Fins per inch10
Fan size180mm
Alphacool fan cable 3-Pin to 3-Pin extension 15cm
€1.98 *
17%
SZ Schlauchklemme bis 15mm
hose clamp up to 15mm
€5.49 *
Delivery date: in 2 - 3 weeks
€1.79 *
