Alphacool Eiskoffer - Multi-Bending Feeder Small
  • 90355
  • 4250197136952
  • 0,132 kg
€26.98 *
Multi-bending feeder possible angles: 30°, 45°, 60°, 90° Small version Pipes with Ø... more
Small version
Pipes with Ø 13 or 12 mm are bent by a radius of 23.5 mm Pipes with Ø 16 mm are bent by a radius of 22 mm
Do not bend more than an added angle of 180° so that your pipe can be removed again when it has cooled down.
All bending guides and stops are designed for pipe diameters of 12 or 13 mm and 16 mm. The required guide is always aligned downwards.
manual
hose cutter aluminum replacement blade 3-19mm
€2.59 *
Alphacool pull saw for acrylic/PETG pipes 35cm
Content 35 Zentimeter (€51.37 * / 100 Zentimeter)
€25.98 *
€28.98 *
€37.98 *
€23.98 *
€39.98 *
€26.98 *
€20.98 *
