Phobya 2pin-Kabel Verlängerung Buchse/Stecker - 30cm
  • ZK
  • 4049469081096
  • 0,019 kg
€4.48 *
Content: 30 Zentimeter (€14.93 * / 100 Zentimeter)
This 2-Pin extension cable can be sued for sensors which are too far away... more
This 2-Pin extension cable can be sued for sensors which are too far away from the monitoring device. Especially in larger cases or when attempting cable management out of sight these extension come in very hand.
Of course this cable can also be used for many more applications such as the case speakers or power- or reset-button.
Technical specifications:
Connectors: 2-Pin to 2-Pin extension
Colour: Black
Length: 30cm
Conforms with RoHS
Extent of delivery:
1x Phobya 2pin-cable extension plug/socket 30cm black
ZK Phobya 2pin-Kabel Verlängerung Buchse/Stecker 30cm - Schwarz
€4.48 *
ZK Phobya 2pin-Kabel Verlängerung Buchse/Stecker 60cm - Schwarz
Content 60 Zentimeter (€7.47 * / 100 Zentimeter)
€4.48 *
Hint!
LK Phobya Verlängerung 3Pin - Schwarz 30cm EOL
Content 30 Zentimeter (€10.60 * / 100 Zentimeter)
€3.18 *
SZ Alphacool Schlauchabschneider Alu 3-19mm
WÄM Alphacool Apex Wärmeleitpad Soft 18W/mk 100x100x1,5mm
Alphacool Apex Thermal Pad Soft 18W/mk 100x100x1,5mm
Content 100 cm² (€2.00 * / 1 cm²)
€199.98 *
Alphacool Apex Thermal Pad Soft 18W/mk 100x100x1mm
Content 100 cm² (€1.40 * / 1 cm²)
€139.98 *
WÄM Alphacool Apex Wärmeleitpad Soft 18W/mk 100x100x0,5mm
Alphacool Apex Thermal Pad Soft 18W/mk 100x100x0,5mm
Content 100 cm² (€1.00 * / 1 cm²)
€99.98 *
WAC Alphacool Eisbaer Pro ES (Solo) Full Black
€72.99 *
Content 1 Gramm (€7,980.00 * / 1000 Gramm)
SEN Alphacool Eiszapfen Temperatursensor flach G1/4 - schwarz
Alphacool Eiszapfen temperature sensor flat G1/4 - Black
WZS Alphacool Spritzflasche Core 250ml
Alphacool Filling bottle Core 250ml
€4.48 *
Content 5 Gramm (€1,396.00 * / 1000 Gramm)
ANK Alphacool ES Distro Plate C1
Alphacool Tubing AlphaTube HF 19/13 (1/2"ID) - Ultra Clear 3m (9,8ft) "Retail Package"
Content 300 Zentimeter (€7.99 * / 100 Zentimeter)
€23.98 *
Alphacool tubing AlphaTube HF 11/8 (5/16"ID) - Ultra Clear 3m (9,8ft) "Retail Package"
Content 300 Zentimeter (€3.16 * / 100 Zentimeter)
€9.48 *
€76.98 *
Alphacool HF compression Fitting TPV Metall - 12,7/7,6mm Straight - Black - 6pcs Kit
Content 6 Stück (€4.66 * / 1 Stück)
€27.98 *
Alphacool connection cable 3pin to 3pol Digital RGB - 15cm
€4.48 *
Alphacool Eisblock XPX Pro 1U
€99.98 *
Liefertermin: in 8 - 9 Wochen
Alphacool tubing AlphaTube HF 16/10 (3/8"ID) - clear 3m (9,8ft) Retailbox
Alphacool GPU RAM Copper Heatsinks 14x14mm - 10pcs
ANK Alphacool HF Schnellverschlusskupplungsset 11/8mm - Black
Alphacool HF quick release connector kit 11/8mm - black
Alphacool NexXxos fan mounting screw M3 x 30 mm - 4 pcs
€3.98 *
Hint!
ZK Phobya Connector 2Pin Stecker inkl. 2 Pins - 10 Stück Black EOL
Content 10 Stück (€0.09 * / 1 Stück)
€0.90 *
LK Phobya 3er Set 3Pin Verlängerung 80cm
Content 80 Zentimeter (€5.60 * / 100 Zentimeter)
€4.48 *
WAN Alphacool HF 14 Smart Motion Universal Copper Edition
Alphacool HF 14 Smart Motion universal copper edition
€38.98 *
