Alphacool Eisblock Aurora Geforce RTX 4070 TI TUF Gaming with Backplate
  • 13730
  • 4250197137300
  • 1,5 kg
€159.98 *
90334 Alphacool Eisplateau Anti-Static work- and mounting mat 120x60cm
€59.98*
17453 Alphacool HF compression Fitting TPV - 12,7/7,6mm Straight - Black - 6pcs Kit
€16.98*
17468 Alphacool Eiszapfen screw plug V.2 G1/4 - deep black
€3.98*
17475 Alphacool Eiszapfen PRO 13mm HardTube fitting G1/4 - deep black sixpack
€44.98*
12987 Alphacool Eisblock Aurora Terminal flat straight - Acetal
€16.98*
€12.98*
The next generation - the Alphacool Eisblock Aurora water cooler for Geforce RTX 40XX graphics... more
The next generation - the Alphacool Eisblock Aurora water cooler for Geforce RTX 40XX graphics cards. In order to dissipate the enormous heat of this graphics card generation in the best possible way, numerous optimizations have been made to the water cooler compared to the previous model. The fin structure was adapted and enables a very good water flow while increasing the cooling surface. The modified jet plate with improved inflow engine ensures an optimal distribution of the water on the cooling fins.
Technical Highlights
Chrome-plated copper
Design
The Aurora design of the Geforce RTX 40XX Eisblock generation is visually calmer and simpler. Only one O-ring runs around the entire cooler. The design around the cooling fins and jetplate makes for a cleaner look. The illumination of the digitally addressable RGB LEDs is even better distributed throughout the cooler as a result of the chrome plating. The terminal's design is in line with the classic Aurora design.
Thermal paste & thermal pads
The included thermal compound is Alphacool's Subzero. With a thermal conductivity of 16 W/mK, it is one of the highest performing thermal pastes on the market. The electrically non-conductive thermal compund is particularly well suited for high contact pressures, but can still be processed perfectly due to its viscosity of 850.000 TF. Alphacool Soft Pads with 1mm thickness are used on the voltage converter and the graphics memory. The thermal conductivity of the pads is 7 W/mK. The pads for the back of the PCB are 3mm thick and have a thermal conductivity of 3 W/mK.
- Asus TUF Gaming GeForce RTX 4070 Ti OC, TUF-RTX4070TI-O12G-GAMING, 12GB GDDR6X (90YV0IJ0-M0NA00)
- Asus TUF Gaming GeForce RTX 4070 Ti, TUF-RTX4070TI-12G-GAMING, 12GB GDDR6X (90YV0IJ1-M0NA00)
Technical data cooler
Dimensions (L x W x H)231,00 x 142,50 x 36,27mm
Material cooler topacrylic
Threads4 x G1/4"
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs13
Colortransparent
Technical data backplate
Dimensions (L x W x H)231,00 x 118,00 x 6,00mm
Materialaluminium
Material Bodenplatte: Kupfer;
Hardware Hersteller: NVIDIA
Material Deckel: Acryl;
Kühlertyp: Komplettkühler
Anschluss: 4x G1/4"
Hardware Modell: RTX 4070 Ti;
Abmessungen: 231,00 x 142,50 x 36,27mm
WAK Alphacool Eisblock Aurora Acryl GPX-A Radeon 5600/5700 XT Gaming X EOL
€69.99 * €129.97 *
WAK Alphacool Eisblock Aurora Acryl GPX-A Radeon 5600/5700 XT Red Devil EOL
€74.07 * €99.98 *
WAK Alphacool Eisblock Aurora Acryl GPX-A Radeon RX 5700 XT Taichi X8 8G OC EOL
€69.99 * €99.98 *
WAK Alphacool Eisblock Aurora Acryl GPX-A Radeon RX 5700 XT Thicc II / III EOL
€69.98 * €109.98 *
Content 3.5 Gramm (€3,708.57 * / 1000 Gramm)
WZS Spritzflasche 500ml PE-LD
€4.19 *
€33.98 *
SEN Alphacool Eiszapfen Temperatursensor flach G1/4 - chrom
Alphacool Eiszapfen temperature sensor flat G1/4 - chrom
ANZ Alphacool Eiszapfen Verschlussschraube V.2 G1/4 - Deep Black
€3.98 *
S13 Alphacool Schlauch AlphaTube HF 13/10 (3/8"ID) - UV Blau 1m (3,3ft) Retailbox 100cm
Alphacool tub AlphaTube HF 13/10 (3/8"ID) - UV blue 1m (3,3ft) Retailbox
€5.99 * €7.89 *
SZ Alphacool HardTube Heat Gun Pro 2000W
€17.98 * €24.98 *
PUZ Alphacool Pumpenbefestigung Universal für 120-140er Lüfter/Radiatoren
Alphacool pump mount universal for 120-140mm fans/radiators
€11.98 * €13.99 *
Alphacool decoupling kit Eheim/Hydor 4 decouplers
€3.48 *
Alphacool Core 1 Aurora Black
€119.98 *
WAC Alphacool Core 1 Silver
€99.98 *
€99.98 *
Content 4 Stück (€6.75 * / 1 Stück)
€26.98 *
Content 4 Gramm (€3,995.00 * / 1000 Gramm)
KOI Alphacool Core Wind 360mm ST30 Wasserkühlungs Set
Alphacool Core Wind 360mm ST30 water cooling Set
€229.98 * €249.98 *
PUM Alphacool Rise Flat Reservoir D5 mit VPP Pumpe
Alphacool Rise Flat Reservoir D5 with VPP pump
€149.98 *
Alphacool tubing AlphaTube HF 10/8 (5/16"ID) - Ultra Clear 3m (9,8ft) Retailbox
Content 300 Zentimeter (€2.66 * / 100 Zentimeter)
Alphacool Eisbaer TPV Extension kit (tube and fittings)
Content 2 Stück (€7.70 * / 1 Stück)
€15.39 *
Leak Testing Tool incl. Pump
€34.98 *
PUM Alphacool Core 200 Aurora Ausgleichsbehälter Acetal/Acryl mit VPP Pumpe
Alphacool Core 200 Aurora Reservoir Acetal/Acryl with Apex Pump
€89.98 * €124.99 *
Content 6 Stück (€7.50 * / 1 Stück)
€44.98 *
Alphacool connection cable 3pin to 3pol Digital RGB - 15cm
€4.48 *
RAD Alphacool NexXxoS XT45 Full Copper 360mm Radiator V.2 PHT EOL
Alphacool NexXxoS XT45 Full Copper 360mm radiator V.2
€89.98 * €109.98 *
RAD Alphacool NexXxoS ST30 Full Copper 240mm Radiator V.2
Alphacool NexXxoS ST30 Full Copper 240mm radiator V.2
€59.98 * €69.98 *
Alphacool tubing AlphaTube HF 16/10 (3/8"ID) - clear 3m (9,8ft) Retailbox
WACZ Alphacool Aurora XPX RGB Frame - Black
Alphacool Aurora XPX RGB frame - black
€8.98 * €9.95 *
KOI Alphacool Eisbaer LT360 CPU - Black
Alphacool Eisbaer LT360 CPU - black
€119.98 *
WAC Alphacool Eisblock XPX CPU - polished Clear Version
Alphacool Eisblock XPX CPU - polished clear version
€49.98 * €59.98 *
