Alphacool Apex Thermal Pad Soft 18W/mk 100x100x1mm
  • 13483
  • 4250197134835
  • 0,051 kg
€99.98 *
Content: 100 cm² (€1.00 * / 1 cm²)
€4.28*
€69.98*
13482 Alphacool Apex Thermal Pad Soft 18W/mk 100x100x0,5mm
€59.98*
13486 Alphacool Apex Thermal Pad Soft 18W/mk 120x20x1mm
€39.98*
Alphacool offers a wide range of thermal pads for effective heat dissipation of electric... more
Powerful!
Increased lifespan!
Versatile!
Technical data thermal pad
Dimensions (L x W x H)100 x 100 x 1mm
Thermal Conductivity (ASTM D5470)17.8 W/mK (±10%)
Hardness (ASTM D2240)65 (Shore 00) (±5)
Working temperature-50 to ~150°C
Volume Resistance (ASTM D257)6×10¹² Ohm-m
Dielectric Breakdown Voltage (ASTM D149)4 KV/mm (±10%)
Density (ASTM D792)3.5 g/cm³ (±10%)
Elongation (ASTM D412)20%
Flame Rating (UL 94)V-0
Colorlight grey
€0.98 *
€1.19 *
Alphacool Core Thermal Pad Soft 9W/mk 100x100x3mm
Content 100 cm² (€0.50 * / 1 cm²)
€49.98 *
WÄM Alphacool Apex Wärmeleitpad Soft 18W/mk 100x100x0,5mm
Content 100 cm² (€0.60 * / 1 cm²)
€59.98 *
WÄM Alphacool Apex Wärmeleitpad Soft 18W/mk 120x20x1mm
Content 24 cm² (€1.67 * / 1 cm²)
€39.98 *
WÄM Alphacool Apex Wärmeleitpad Soft 18W/mk 100x100x1,5mm
Alphacool Apex Thermal Pad Soft 18W/mk 100x100x1,5mm
Content 100 cm² (€1.80 * / 1 cm²)
€179.98 *
Alphacool Core Thermal Pad Soft 9W/mk 100x100x2mm
Content 100 cm² (€0.37 * / 1 cm²)
€36.99 *
Delivery date: in 3 - 4 days
WÄM Alphacool Apex Wärmeleitpad Soft 16W/mk 100x100x1,5mm
Alphacool Apex Thermal Pad Soft 16W/mk 100x100x1,5mm
Content 100 cm² (€1.20 * / 1 cm²)
€119.98 *
WÄM Alphacool Apex Wärmeleitpad Soft 16W/mk 100x100x1mm
Alphacool Apex Thermal Pad Soft 16W/mk 100x100x1mm
Content 100 cm² (€0.75 * / 1 cm²)
€74.98 *
Alphacool Core Thermal Pad Soft 9W/mk 100x100x1mm
Content 100 cm² (€0.22 * / 1 cm²)
€21.98 *
WÄM Alphacool Apex Soft Wärmeleitpad 14W/mk 2x 120x20x1mm
Alphacool Apex Soft thermal pad 14W/mk 2x 120x20x1mm
Content 48 cm² (€0.94 * / 1 cm²)
€44.98 *
€4.97 *
Delivery date: in 5 - 6 weeks
