Alphacool Apex Thermal Pad Soft 18W/mk 100x100x0,5mm
- Article no.: 13482
- EAN: 4250197134828
- Weight: 0,031 kg
- Available: Currently there are 2 available - More is on the way
Powerful!
Increased lifespan!
Versatile!
| Dimensions (L x W x H) | 100 x 100 x 0,5mm |
| Thermal Conductivity (ASTM D5470) | 17.8 W/mK (±10%) |
| Hardness (ASTM D2240) | 65 (Shore 00) (±5) |
| Working temperature | -50 to ~150°C |
| Volume Resistance (ASTM D257) | 6×10¹² Ohm-m |
| Dielectric Breakdown Voltage (ASTM D149) | 4 KV/mm (±10%) |
| Density (ASTM D792) | 3.5 g/cm³ (±10%) |
| Elongation (ASTM D412) | 20% |
| Color | light grey |
