Phobya Verlängerung 3Pin Molex extra lang - Schwarz 60cm
- Article no.: LK
- EAN: 4049469077921
- Weight: 0,008 kg
Extension cable for 3-Pin cables e.g. for fans. With rpm signal lead.
Sleeving:
Sets:
Technical specifications:
Connectors: 3-Pin extension
Black sleeve, black connectors and black heatshrink
Length: 60cm
Conforms with RoHS
Extent of delivery:
1x Phobya extension cable 3-Pin Molex 60cm - black
This product has been reviewed for you:
Aquainfos
Tech-Review
2. Seite: | 1x 3Pin |
Sleeving: | schwarz |
1. Seite: | 1x 3Pin |
Hersteller: | Phobya |
Bauform: | Verlängerung |
![LK Phobya Verlängerung 3Pin - Schwarz 30cm EOL](https://aquatuning.shop-cdn.com/media/image/1e/f3/7e/81028_1TUhirHLck7yLz_200x200..jpg)
![LK Phobya Verlängerung 3Pin - UV Blau 30cm EOL](https://aquatuning.shop-cdn.com/media/image/0c/58/d0/81030_1mQyy9ZN1UbEYH_200x200..jpg)
![LK Phobya Y-Kabel 3Pin Molex auf 9x 3Pin Molex - Schwarz 60cm EOL](https://aquatuning.shop-cdn.com/media/image/01/66/c6/81049_1ldz6clB4id7j0_200x200..jpg)
![LK Phobya Adapter 3Pin (12V) auf 3Pin (7V) 20cm EOL](https://aquatuning.shop-cdn.com/media/image/e8/c0/28/81067_1U2CudqeNwLq5u_200x200..jpg)
![LK Phobya 4Pin PWM Verlängerung - Schwarz 60cm](https://aquatuning.shop-cdn.com/media/image/7f/40/da/81092_1MzMueJ4xNN7xz_200x200..jpg)
![LK Phobya 4Pin PWM Verlängerung - Schwarz 90cm](https://aquatuning.shop-cdn.com/media/image/bb/58/d6/81134_1LL5rBsrWLnfwo_200x200..jpg)
![LK Phobya Verlängerung 3Pin Molex ultra lang - Schwarz 90cm EOL](https://aquatuning.shop-cdn.com/media/image/aa/f2/18/81133_1u9D7FG1paA26I_200x200..jpg)
![WAK Alphacool Eisblock Aurora Acryl RX 7900XTX/XT Taichi/Phantom mit Backplate](https://aquatuning.shop-cdn.com/media/image/fb/67/db/1023243_1flGaxciCcivb4_200x200..jpg)
![KAB Alphacool Y-Splitter aRGB 3-Pin auf 4x 3-Pin 30cm](https://aquatuning.shop-cdn.com/media/image/0c/91/70/1023148_01_200x200..jpg)
![KAB Alphacool Y-Splitter aRGB 3-Pin auf 3x 3-Pin 30cm](https://aquatuning.shop-cdn.com/media/image/dc/b2/4d/1023145_01d7SSyM10BMqsW_200x200..jpg)
![KAB Alphacool Verlängerung aRGB 3-Pin auf 3-Pin 30cm](https://aquatuning.shop-cdn.com/media/image/e9/a5/bb/1023139_01_200x200..jpg)
![LK Alphacool Y-Splitter 3-Pin auf 3x 3-Pin 30cm](https://aquatuning.shop-cdn.com/media/image/d2/82/74/1023130_01_200x200..jpg)
![ANS Alphacool Eiszapfen 13/10mm Anschraubtülle 90° drehbar G1/4 - 4pcs Set Deep Black](https://aquatuning.shop-cdn.com/media/image/aa/3d/46/1022485_1DYrNWrtaKb4bh_200x200..jpg)
![WAZ Alphacool Eiswasser Crystal Yellow Fertiggemisch 1000ml](https://aquatuning.shop-cdn.com/media/image/7e/g0/47/1014013_1487GKvHaOZAko_200x200..jpg)
![ANS Alphacool HF 13/10 Anschraubtülle G1/4 - Deep Black Sixpack](https://aquatuning.shop-cdn.com/media/image/85/7c/4b/1012846_1Pyedsi3E7G4p1_200x200..jpg)
![LK Phobya 4Pin PWM Stecker auf Stecker - Schwarz 60cm](https://aquatuning.shop-cdn.com/media/image/54/15/0f/1012291_1Cy4aIYYdTb5j4_200x200..jpg)
![LK Phobya 4Pin PWM Stecker auf Stecker - Schwarz 30cm](https://aquatuning.shop-cdn.com/media/image/eb/d7/3d/1012290_1tlvQkhD7AzAfN_200x200..jpg)
![LK Phobya Y-Kabel 4Pin PWM auf 4x 4Pin PWM - Schwarz 60cm](https://aquatuning.shop-cdn.com/media/image/25/9d/04/1011110_1Wj6PAymPH3MMp_200x200..jpg)
![ZK Phobya 2pin-Kabel Verlängerung Buchse/Stecker 60cm - Schwarz](https://aquatuning.shop-cdn.com/media/image/c7/f9/cf/82395_1htpdMgr639sYa_200x200..jpg)
![LK Phobya 4Pin PWM Verlängerung - Schwarz 30cm](https://aquatuning.shop-cdn.com/media/image/b4/7a/06/81086_1jJ5qbCz3P4VkA_200x200..jpg)
![LK Phobya Y-Kabel 3Pin Molex auf 2x 3Pin Molex - Schwarz 30cm](https://aquatuning.shop-cdn.com/media/image/0f/4b/d5/81023_1pIX0AoVwbz2uE_200x200..jpg)
