Phobya Y-Kabel 3Pin Molex auf 2x 3Pin Molex - Schwarz 30cm
  • LK
  • 4049469077822
  • 0,011 kg
€3.48 *
Content: 30 Zentimeter (€11.60 * / 100 Zentimeter)
For connection of 2 fans with 3-Pin connectors to a 3-Pin connector e.g. on the Mainboard.... more
For connection of 2 fans with 3-Pin connectors to a 3-Pin connector e.g. on the Mainboard. Please note that the speed monitoring of only one connected fan is possible with this adaptor cable. A white sticker on one of the cables shows which connector can be monitored.
Sleeving:
This cable is not only practical, it is also optically appealing, The surrounding mesh, also called sleeve, which is surrounding the cable itself offers the advantages that every Pro-modder is looking for: A completely unique look, even of the cables in the system! Special attention was paid to the combination of cable connectors, sleeve and heatshrink which were used to ensure great design and a unique as well as elegant look.
The idea behind these cables:
Technical specifications:
Connectors: 3-Pin to 2x 3-Pin Y-cable
Colour: Black sleeve, black connectors and black heatshrink
Dimensions: 30cm length each
Conforms with RoHS
Extent of delivery:
1x Phobya Y-cable 3-Pin Molex to 2x 3-Pin Molex 30cm - Black
Please note: If connecting multiple fans to one fan socket by using this adapters please ensure that the source is specified to supply enough current to safely supply all fans together. Too high loads may result in damages to the system.
This product has been reviewed for you:
Aquainfos
Tech-Review
Bauform: Y-Kabel
Hersteller: Phobya
Sleeving: schwarz
1. Seite: 1x 3Pin
2. Seite: 2x 3Pin
Hint!
LK Phobya Verlängerung 3Pin - Schwarz 30cm EOL
Content 30 Zentimeter (€10.60 * / 100 Zentimeter)
€3.18 *
€5.68 *
Hint!
LK Phobya Y-Kabel 3Pin Molex auf 9x 3Pin Molex -  Schwarz 60cm EOL
LK Phobya Adapter 3Pin (12V) auf 3Pin (7V) - Schwarz 20cm
Content 20 Zentimeter (€17.40 * / 100 Zentimeter)
€3.48 *
Hint!
LK Phobya Verlängerung 3Pin Molex ultra lang -  Schwarz 90cm EOL
Content 90 Zentimeter (€6.09 * / 100 Zentimeter)
€5.48 *
Hint!
€3.18 *
€2.98 *
KAB Phobya 4Pin Molex Stromverlängerung - Schwarz 60cm
€5.68 *
LK Phobya Y-Kabel 4Pin PWM auf 3x 4Pin PWM - Schwarz 30cm
€4.48 *
Hint!
L14 Noiseblocker NB-BlackSilentPRO PK1 ( 140x140x25mm )
€18.90 *
Hint!
LK Phobya Verlängerung 3Pin Molex extra lang -  Schwarz 60cm EOL
Content 60 Zentimeter (€7.47 * / 100 Zentimeter)
€4.48 *
Content 60 Zentimeter (€8.30 * / 100 Zentimeter)
€4.98 *
Content 30 Zentimeter (€16.60 * / 100 Zentimeter)
€4.98 *
WAC Alphacool Core 1 Aurora Silver
€119.98 *
WAC Alphacool Core 1 Silver
€99.98 *
€99.98 *
Content 100 cm² (€0.37 * / 1 cm²)
€36.99 *
Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x2mm
Content 100 cm² (€0.29 * / 1 cm²)
€28.98 *
Alphacool y-splitter 3-Pin to 3x 3-Pin 30cm
€4.98 *
€4.98 *
Content 15 Zentimeter (€33.20 * / 100 Zentimeter)
€4.98 *
€69.98 *
AGB Alphacool Core Distro Plate 360 Rechts mit VPP Pumpe
Alphacool Core Distro Plate 360 right with VPP Apex pump
€249.98 *
WACZ Alphacool Backplate mit Schrauben LGA 115x/1200/1700
Alphacool Backplate with Screws LGA 115x/1200/1700
€6.48 *
SEN Alphacool Eiszapfen Temperatursensor flach G1/4 - schwarz
Alphacool Eiszapfen temperature sensor flat G1/4 - Black
WAH Alphacool HDX Apex Acetal M.2 2280 SSD Kühler
Alphacool HDX Apex Acetal M.2 2280 SSD Cooler
€30.00 *
WZS Alphacool ES Big Inline Partikelfilter 2x G1/4" IG
Alphacool ES Big Inline particle filter 2x G1/4" IG
€29.98 *
€44.98 *
Alphacool Universal feet for radiators
Content 2 Stück (€12.49 * / 1 Stück)
€24.98 *
17565 Alphacool Eiszapfen Pro 13mm spare parts
Content 10 Stück (€0.56 * / 1 Stück)
€5.58 *
S13 Alphacool Schlauch AlphaTube HF 13/10 (3/8"ID) - UV Weiß 1m (3ft) Retailbox
Alphacool tubing AlphaTube HF 13/10 (3/8"ID) - UV white 1m (3ft) Retailbox
RAD Alphacool NexXxos ST30 Full Copper 280mm vorbefüllt AIO Edition
Alphacool NexXxos ST30 Full Copper 280mm prefilled AIO Edition
€89.98 * €102.98 *
