Alphacool Core thermal pad Soft 9W/mk 40x40x1.5mm
  • 13422
  • 4250197134224
  • 0,022 kg
Content: 16 cm² (€0.50 * / 1 cm²)
€4.28*
€69.98*
WÄM Alphacool Core thermal pad Soft 9W/mk 100x100x1.5mm
€29.98*
WÄM Alphacool Core thermal pad Soft 9W/mk 40x40x2mm
€9.98*
WÄM Alphacool Core thermal pad Soft 9W/mk 120x20x1.5mm
€11.98*
Alphacool's performance thermal pad can be used to cool electronic components of all kinds where... more
Increased service life!
Versatile use!
Technical data thermal pad
Dimensions (L x W x H)40 x 40 x 1,5mm
Thermal Conductivity (ASTM D5470)9.0 W/mK (±10%)
Hardness (ASTM D2240)50 (Shore 00) (±15)
Working temperature-50 to ~180°C
Volume Resistance (ASTM D257)1×10¹² Ohm-m
Dielectric Breakdown Voltage (ASTM D149)≥8 KV/mm
Density (ASTM D792)3.2 g/cm³ (±10%)
Elongation (ASTM D412)40%
Flame Rating (UL 94)V-0
Colorpink
Fastening: Slightly adhesive
Thickness: 1,5mm
Surface dimensions: 40 x 40mm
Thermal conductivity: 9,0W/mk
Content 16 cm² (€0.62 * / 1 cm²)
WÄM Alphacool Core Wärmeleitpad Soft 9W/mk 40x40x1mm
Alphacool Core thermal pad Soft 9W/mk 40x40x1mm
Content 16 cm² (€0.44 * / 1 cm²)
€6.99 *
WAC Alphacool Core 1 Silver
€99.98 *
Alphacool Core double-sided adhesive thermal pad 100x100x0.25mm
Content 100 cm² (€0.07 * / 1 cm²)
€6.99 *
WÄM Alphacool Apex Wärmeleitpad Soft 16W/mk 120x20x1,5mm
Alphacool Apex thermal pad Soft 16W/mk 120x20x1.5mm
Content 24 cm² (€1.87 * / 1 cm²)
€44.98 *
WÄM Alphacool Apex Wärmeleitpad Soft 16W/mk 120x20x1mm
Alphacool Apex thermal pad Soft 16W/mk 120x20x1mm
Content 24 cm² (€1.46 * / 1 cm²)
€34.97 *
Content 24 cm² (€0.50 * / 1 cm²)
€11.98 *
Alphacool Core thermal pad Soft 9W/mk 40x40x3mm
Content 16 cm² (€0.81 * / 1 cm²)
WÄM Alphacool Core Wärmeleitpad Soft 9W/mk 40x40x0,5mm
Alphacool Core thermal pad Soft 9W/mk 40x40x0.5mm
Content 16 cm² (€0.37 * / 1 cm²)
€5.99 *
Alphacool Core thermal pad Soft 9W/mk 100x100x1mm
Content 100 cm² (€0.22 * / 1 cm²)
€21.98 *
Alphacool Core thermal pad Soft 6.2W/mk 100x100x3mm
Content 100 cm² (€0.33 * / 1 cm²)
€32.97 *
Alphacool Eiszapfen screw plug G1/4 - 6pcs Set Chrome
Content 6 Stück (€2.16 * / 1 Stück)
25%
KOI Alphacool Core Ocean T38 AIO 360mm
€56.98 * €75.98 *
Alphacool Apex Soft thermal pad 11W/mk 2x 120x20x1mm
Content 48 cm² (€0.40 * / 1 cm²)
€29.98 *
WAGZ Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 50x50x2mm
Content 25 cm² (€0.28 * / 1 cm²)
€6.99 *
13%
€6.49 * €8.98 *
29%
PUM Alphacool Core 100 Aurora Ausgleichsbehälter Acetal/Acryl mit VPP Pumpe
Alphacool Core 100 Aurora reservoir acetal/acrylic with Apex pump
€84.98 * €118.98 *
Content 6 Stück (€4.66 * / 1 Stück)
€27.98 *
Content 330 Zentimeter (€5.75 * / 100 Zentimeter)
