Alphacool Core Thermal Pad Soft 9W/mk 40x40x1mm
  • 13421
  • 4250197134217
  • 0,019 kg
€4.78 * €6.99 * (31.62% Saved)
Content: 16 cm² (€0.30 * / 1 cm²)
€4.28*
€69.98*
13416 Alphacool Core Thermal Pad Soft 9W/mk 100x100x1mm
€11.78*
13423 Alphacool Core Thermal Pad Soft 9W/mk 40x40x2mm
€6.18*
13426 Alphacool Core Thermal Pad Soft 9W/mk 120x20x1mm
€5.68*
Alphacool's performance thermal pad can be used to cool electronic components of all kinds where... more
Increased service life!
Versatile use!
Technical data thermal pad
Dimensions (L x W x H)40 x 40 x 1mm
Thermal Conductivity (ASTM D5470)9.0 W/mK (±10%)
Hardness (ASTM D2240)50 (Shore 00) (±15)
Working temperature-50 to ~180°C
Volume Resistance (ASTM D257)1×10¹² Ohm-m
Dielectric Breakdown Voltage (ASTM D149)≥8 KV/mm
Density (ASTM D792)3.2 g/cm³ (±10%)
Elongation (ASTM D412)40%
Flame Rating (UL 94)V-0
Colorpink
31%
€23.98 * €34.97 *
Content 100 cm² (€0.86 * / 1 cm²)
€86.28 * €119.98 *
Alphacool Core Thermal Pad Soft 9W/mk 40x40x1,5mm
Content 16 cm² (€0.35 * / 1 cm²)
€5.58 * €7.98 *
38%
Content 16 cm² (€0.39 * / 1 cm²)
€6.18 * €9.98 *
32%
WÄM Alphacool Core Wärmeleitpad Soft 9W/mk 40x40x0,5mm
Alphacool Core Thermal Pad Soft 9W/mk 40x40x0,5mm
Content 16 cm² (€0.26 * / 1 cm²)
€4.08 * €5.99 *
Alphacool Core double sided adhesive thermal pad 100x100x0.25mm
Content 100 cm² (€0.07 * / 1 cm²)
€6.99 *
46%
WÄM Alphacool Apex Wärmeleitpad Soft 16W/mk 120x20x1mm
Alphacool Apex Thermal Pad Soft 16W/mk 120x20x1mm
Content 24 cm² (€0.79 * / 1 cm²)
€18.98 * €34.97 *
WAC Alphacool Core 1 Silver
42%
Alphacool Core Thermal Pad Soft 9W/mk 120x20x1,5mm
Content 24 cm² (€0.29 * / 1 cm²)
€6.99 * €11.98 *
41%
Alphacool Core Thermal Pad Soft 9W/mk 40x40x3mm
Content 16 cm² (€0.48 * / 1 cm²)
€7.68 * €12.98 *
43%
€3.97 * €6.99 *
€83.98 *
Alphacool GPU RAM Copper Heatsinks 6.5x6.5mm - 10 pcs.
Content 10 Stück (€1.00 * / 1 Stück)
Alphacool NexXxoS ST30 Full Copper 240mm radiator
€51.98 *
