Alphacool Core Thermal Pad Soft 9W/mk 40x40x0,5mm
  • 13420
  • 4250197134200
  • 0,016 kg
€4.08 * €5.99 * (31.89% Saved)
Content: 16 cm² (€0.26 * / 1 cm²)
€4.28*
€69.98*
13422 Alphacool Core Thermal Pad Soft 9W/mk 40x40x1,5mm
€5.58*
13425 Alphacool Core Thermal Pad Soft 9W/mk 120x20x0,5mm
€4.58*
Alphacool's performance thermal pad can be used to cool electronic components of all kinds where... more
Increased service life!
Versatile use!
Technical data thermal pad
Dimensions (L x W x H)40 x 40 x 0,5mm
Thermal Conductivity (ASTM D5470)9.0 W/mK (±10%)
Hardness (ASTM D2240)50 (Shore 00) (±15)
Working temperature-50 to ~180°C
Volume Resistance (ASTM D257)1×10¹² Ohm-m
Dielectric Breakdown Voltage (ASTM D149)≥8 KV/mm
Density (ASTM D792)3.2 g/cm³ (±10%)
Flame Rating (UL 94)V-0
Colorpink
Elongation (ASTM D412)40%
31%
€23.98 * €34.97 *
Content 100 cm² (€0.86 * / 1 cm²)
€86.28 * €119.98 *
32%
WÄM Alphacool Core Wärmeleitpad Soft 9W/mk 40x40x1mm
Alphacool Core Thermal Pad Soft 9W/mk 40x40x1mm
Content 16 cm² (€0.30 * / 1 cm²)
€4.78 * €6.99 *
42%
Alphacool Core Thermal Pad Soft 9W/mk 120x20x1,5mm
Content 24 cm² (€0.29 * / 1 cm²)
€6.99 * €11.98 *
38%
Alphacool Core Thermal Pad Soft 9W/mk 40x40x2mm
Content 16 cm² (€0.39 * / 1 cm²)
€6.18 * €9.98 *
Content 16 cm² (€0.35 * / 1 cm²)
€5.58 * €7.98 *
27%
Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x2mm
Content 16 cm² (€0.32 * / 1 cm²)
€5.08 * €6.99 *
50%
Alphacool Apex Soft thermal pad 11W/mk 2x 120x20x1mm
Content 48 cm² (€0.20 * / 1 cm²)
€9.58 * €18.98 *
€6.49 * €8.98 *
