  • 13406
  • 4250197134064
  • 0,108 kg
  • Currently there are 9 available
€32.97 *
Content: 100 cm² (€0.33 * / 1 cm²)
€4.28*
€69.98*
13404 Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x1,5mm
€21.98*
13411 Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x3mm
€8.98*
13414 Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1,5mm
€7.98*
Alphacool's performance thermal pad can be used to cool electronic components of all kinds where... more
Increased service life!
Versatile use!
Technical data thermal pad
Dimensions (L x W x H)100 x 100 x 3mm
Thermal Conductivity (ASTM D5470)6.2 W/mK (±10%)
Hardness (ASTM D412)50 (Shore 00) (±15)
Working temperature-50 to ~150°C
Volume Resistance (ASTM D257)1×10¹³ Ohm-m
Dielectric Breakdown Voltage (ASTM D149)6 KV/mm (±10%)
Density (ASTM D792)3.1 g/cm³ (±10%)
Elongation (ASTM D412)50%
Flame Rating (UL 94)V-0
Colorblue
WÄM Alphacool Wärmeleitpad für NexXxoS GPX 3W/mk 30x30x3mm yellow marked PE Bag (4 Stück)
Alphacool thermal pad for NexXxoS GPX 3W/mk 30x30x3mm yellow marked PE Bag (4 pieces)
Content 36 cm² (€0.11 * / 1 cm²)
€3.78 *
WÄM Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1mm - 2 Stück PHT EOL
€21.98 *
Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x2mm
€24.98 *
€29.98 *
Alphacool Core Thermal Pad Soft 9W/mk 40x40x2mm
Content 16 cm² (€0.62 * / 1 cm²)
Content 100 cm² (€0.35 * / 1 cm²)
€34.97 *
€3.78 *
€2.48 *
Content 25 cm² (€0.28 * / 1 cm²)
€6.99 *
WÄM Alphacool Eisschicht Wärmeleitpad - 14W/mK 100x100x1mm PHT EOL
Alphacool Ice Layer Thermal Pad - 14W/mK 100x100x1mm
Content 100 cm² (€0.80 * / 1 cm²)
GHE Alphacool ES 19" Open Frame Serverrack 12HE Verstellbare Tiefe
Alphacool ES 19" Open Frame Serverrack 12U Adjustable Depth
€229.98 * €309.38 *
Delivery date: in 5 - 6 weeks
Alphacool y-splitter 4-Pin to 4x 4-Pin PWM 15cm white
Content 15 Zentimeter (€26.47 * / 100 Zentimeter)
€3.97 *
€4.97 *
€2.58 *
WAC Alphacool Core 1 Silver
Alphacool Core Thermal Pad Soft 9W/mk 120x20x1,5mm
Content 24 cm² (€0.50 * / 1 cm²)
€11.98 *
Alphacool Core Thermal Pad Soft 9W/mk 40x40x1,5mm
Content 16 cm² (€0.50 * / 1 cm²)
WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 40x40x3mm
Content 16 cm² (€0.56 * / 1 cm²)
WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 100x100x1mm
Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x1mm
Content 100 cm² (€0.17 * / 1 cm²)
€6.99 *
€69.98 *
WÄM Alphacool Apex Soft Wärmeleitpad 14W/mk 2x 120x20x1mm
Alphacool Apex Soft thermal pad 14W/mk 2x 120x20x1mm
Content 48 cm² (€0.94 * / 1 cm²)
€44.98 *
Alphacool Apex Soft thermal pad 11W/mk 2x 120x20x1mm
Content 48 cm² (€0.40 * / 1 cm²)
WÄM Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 100x100x0,5mm
