Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x3mm
  • 13411
  • 4250197134118
  • 0,029 kg
€5.49 * €8.98 * (38.86% Saved)
Content: 16 cm² (€0.34 * / 1 cm²)
€4.28*
€69.98*
13406 Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x3mm
€17.98*
13407 Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x0,5mm
€3.78*
13414 Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1,5mm
€5.58*
Alphacool's performance thermal pad can be used to cool electronic components of all kinds where... more
Increased service life!
Versatile use!
Technical data thermal pad
Dimensions (L x W x H)40 x 40 x 3mm
Thermal Conductivity (ASTM D5470)6.2 W/mK (±10%)
Hardness (ASTM D412)50 (Shore 00) (±15)
Working temperature-50 to ~150°C
Volume Resistance (ASTM D257)1×10¹³ Ohm-m
Dielectric Breakdown Voltage (ASTM D149)6 KV/mm (±10%)
Density (ASTM D792)3.1 g/cm³ (±10%)
Elongation (ASTM D412)50%
Flame Rating (UL 94)V-0
Colorblue
Content 24 cm² (€0.23 * / 1 cm²)
€5.58 * €7.98 *
33%
Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1mm
Content 24 cm² (€0.20 * / 1 cm²)
€4.68 * €6.99 *
27%
Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x2mm
Content 16 cm² (€0.32 * / 1 cm²)
€5.08 * €6.99 *
22%
WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 40x40x1,5mm
Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x1,5mm
Content 16 cm² (€0.29 * / 1 cm²)
€4.68 * €5.99 *
Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x1mm
Content 16 cm² (€0.22 * / 1 cm²)
€3.58 * €4.97 *
Alphacool y-splitter 4-Pin to 4x 4-Pin PWM 15cm white
Content 15 Zentimeter (€26.47 * / 100 Zentimeter)
€3.97 *
€3.78 *
€2.58 *
42%
Alphacool Core Thermal Pad Soft 9W/mk 120x20x1,5mm
Content 24 cm² (€0.29 * / 1 cm²)
€6.99 * €11.98 *
41%
Alphacool Core Thermal Pad Soft 9W/mk 40x40x3mm
Content 16 cm² (€0.48 * / 1 cm²)
€7.68 * €12.98 *
38%
Alphacool Core Thermal Pad Soft 9W/mk 40x40x2mm
Content 16 cm² (€0.39 * / 1 cm²)
€6.18 * €9.98 *
45%
Content 100 cm² (€0.18 * / 1 cm²)
€17.98 * €32.97 *
48%
Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x2mm
€12.88 * €24.98 *
50%
WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 100x100x1mm
Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x1mm
Content 100 cm² (€0.08 * / 1 cm²)
€8.48 * €16.98 *
€6.99 *
43%
€3.97 * €6.99 *
38%
WÄM Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 50x50x3mm
Content 25 cm² (€0.20 * / 1 cm²)
€4.97 * €7.98 *
21%
€33.97 * €42.98 *
€1.48 *
60%
WACZ Alphacool Aurora XPX RGB Frame - Black PHT EOL
€3.99 * €9.95 *
