  • 13019
  • 4250197130196
  • 0,056 kg
€15.78 * €29.98 * (47.36% Saved)
Content: 100 cm² (€0.16 * / 1 cm²)
€62.98*
ZSO Alphacool antistatic wrist cuff blue
€4.48*
€6.49*
13020 Alphacool Apex Soft Thermal Pad 14W/mk 100x100x1mm
€44.08*
WÄM Alphacool Apex Soft thermal pad 11W/mk 2x 120x20x1mm
€9.58*
The Apex Soft are Alphacool's high-end solution in the field of thermal pads, as they can almost... more
The Apex Soft are Alphacool's high-end solution in the field of thermal pads, as they can almost be compared to thermal paste due to their outstanding properties. The Apex Soft thermal pads fit much better to components, which contributes to a significant improvement in cooling performance.
The material of the Apex Soft thermal pads acts similarly to a thermal paste. The consistency of the pads prevents the highest components, such as voltage converters or VRams, from being subjected to increased contact pressure from the cooler. In the worst case, this can lead to the PCB bending. The Apex Soft Pads fill in uneven areas much better, fit better to the components and thus significantly increase the heat transfer between the cooler and the component.
But that’s not the only advantage!
The special material also cannot dry out. Usually the silicone in thermal pads bleeds over time. This causes them to become hard and the performance of the pads drops rapidly at a certain point. This is not the case with the Apex Soft thermal pads. They can be used for a much longer period of time without losing any significant performance.
Cropping? No problem!
When cutting the thermal pads, you should definitely leave the foil on the pads. This means that the pads can be easily cut to size with scissors. It's just as easy as cutting paper. The cut edges stay perfectly clean and don't fray.
The Alphacool Apex Soft thermal pads offer better performance in many ways than conventional thermal pads and are a perfect replacement for old or low-performance pads.
L x W x H 100x100x1mm
Color Gray
Specific gravity ASTM D792 3.4 g/cc
Thermal conductivity 11.0 W/mK
Hardness ASTM 2240 72 Shore OO
Operating temperature -40 to +150 °C
Volume resistivity ASTM D257 1.0x10 11 Ohm-m
Dielectric constant ASTM D150 7.2MHz
Dielectric breakdown ASTM D149 14 kV/mm
Flame class UL 94 V-0
Weight 40g
Download data sheet PDF: Alphacool Apex Soft thermal pad 11W/mk 100x100x1mm
31%
€23.98 * €34.97 *
Content 100 cm² (€0.86 * / 1 cm²)
€86.28 * €119.98 *
45%
Content 100 cm² (€0.18 * / 1 cm²)
€17.98 * €32.97 *
49%
Alphacool Core Thermal Pad Soft 9W/mk 100x100x2mm
Content 100 cm² (€0.19 * / 1 cm²)
€18.78 * €36.99 *
44%
Alphacool Core Thermal Pad Soft 9W/mk 100x100x3mm
Content 100 cm² (€0.28 * / 1 cm²)
€27.98 * €49.98 *
50%
Content 48 cm² (€0.20 * / 1 cm²)
€9.58 * €18.98 *
43%
€3.97 * €6.99 *
€6.49 * €8.98 *
€1.89 *
31%
WÄM Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1,5mm - 2 Stück PHT EOL
Content 48 cm² (€0.41 * / 1 cm²)
€19.88 * €28.98 *
31%
€23.98 * €34.97 *
WAO Alphacool MCX one
Alphacool MCX one
38%
Alphacool Core Thermal Pad Soft 9W/mk 40x40x2mm
Content 16 cm² (€0.39 * / 1 cm²)
€6.18 * €9.98 *
48%
Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x2mm
€12.88 * €24.98 *
€2.68 *
20%
€3.97 * €4.97 *
Alphacool Eisblock Aurora mounting screws and springs M2x6mm
Content 10 Stück (€0.30 * / 1 Stück)
€2.98 *
€0.99 * €4.89 *
33%
WÄM Alphacool Eisschicht Light Wärmeleitpad - 7W/mK 100x100x0,5mm PHT EOL
Alphacool Eisschicht Light thermal pad - 7W/mK 100x100x0,5mm
Content 100 cm² (€0.05 * / 1 cm²)
€5.38 * €7.98 *
29%
WÄM Alphacool Eisschicht Wärmeleitpad - 14W/mK 120x20x0,5mm - 2 Stück PHT EOL
Alphacool Ice Layer Thermal Pad - 14W/mK 120x20x0.5mm - 2 pieces
Content 48 cm² (€0.45 * / 1 cm²)
€21.38 * €29.98 *
Alphacool NexXxoS GPX accessory pack 3W/mk
Content 108 cm² (€0.04 * / 1 cm²)
€3.97 *
Laing DDC-pump 12V DDC 4.2 PWM
€74.98 * €101.13 *
