Yate Loon D14BH-12 mit Stecker (2300rpm) ( 140x140x25mm )
- Article no.: L14
- EAN: 4049469280437
- Weight: 0,197 kg
Yate Loon offers fans with particularly high static pressure and high air flow. They are particularly suitable for use as powerful case fans and offer extremely high performance even on radiators of a water cooler. Due to the classic frame, they completely cover radiators, so that all air is actually forced through the radiator. Via the 3-pin connector the fans can be easily controlled by voltage.
Technical data:
Dimensions: 140 x 140 x 25mm
Connection: 3-Pin
Voltage: 12V
power consumption: 4,68W
Starting voltage: 6,5V
Speed: 2300 rpm
Air flow rate: 205,6 m³/h
Static pressure: 3,7 mm/H²O
Noise emission: 47 dB(A)
Cable length: 52cm
Größe: | 140mm |
Abmessungen: | 140 x 140 x 25mm |
Farbe Rotor: | schwarz; |
Nennspannung: | 12V DC |
RPM Signalübertragung: | Ja |
Lautstärkebereich: | 30 - 49,9 dB(A) |
Luftförderbereich: | 150 - 199 m³/h |
Farbe Rahmen: | schwarz; |
Nenndrehzahl: | 2300 U/min |
Luftförderleistung: | 100 m³/h |
Lautstärke: | 42 dB(A) |
Lüfterbundle: | 3x;4x;9x; |
Hersteller: | Yate Loon |
LED: | nicht vorhanden; |
Stromanschluss: | 3Pin; |
Liefertermin: in 4 - 5 Tagen
Liefertermin: in 7 - 8 Wochen
