Alphacool Eiswolf 2 AIO - 360mm RTX 3090/3080 with Backplate (Reference)
  • 11931
  • 4250197119313
  • 3,707 kg
€269.98 *
€15.98*
24806 Alphacool Eiszyklon Aurora LUX PRO Digital RGB (120x120x25mm)
€9.98*
11730 Alphacool Eisbaer Aurora 360 CPU - Digital RGB
€169.98*
12982 Alphacool Eisbaer TPV Extension kit (tube and fittings)
€15.39*
14370 Alphacool NexXxos ST30 Full Copper 240mm prefilled AIO Edition
€85.98*
The Alphacool Eiswolf 2 is the first full cover GPU AIO waterblock from Alphacool. It is based... more
Fullcover Waterblock?
Pump
Fittings and Tubing
Expandability
Lighting and fans
The Eiswolf 2 cooler has a digital RGB LED lighting, also called addressable RGB LEDs. They run along the entire back of the graphics card cooler and provide complete illumination of the water cooler. The pump unit is more discreet and offers a green glowing logo for Nvidia and a red glowing logo for AMD cards. The name "Eiswolf" on the pump unit remains unlit, discreetly in the background. The fan used is the Aurora Rise with 120mm. Due to the special blade design, the fan is extremely quiet and the addressable RGB LEDs provide brilliant illumination. The Alphacool Aurora Rise fan convinces with a max. statistical pressure of 3.17mm/H2O and offers a max. air flow of 119.8m3/h. The PWM control allows the fan to be controlled over a wide speed range. In addition, it offers a zero control. It can therefore be regulated down to 0 rpm and then starts with approx. 350 rpm.
NexXxoS Radiator
Technical note!
GPU were approved with photos. Due the limited visuality we can not say for sure if the water block will fit. Please check your PCB Layout before you order the water block
- Gainward RTX 3080 Phoenix (1952)
- Gainward RTX 3080 Phoenix GS (2010)
- Galakuro NVIDIA GEFORCE RTX 3080 GG-RTX3080-E10GB/TP
- Galax GeForce RTX 3080 SG 10GB GDDR6X (38NWM3MD99NN)
- Inno3D GEFORCE RTX 3080 12GB ICHILL BLACK LHR
- Inno3D GEFORCE RTX 3080 12GB ICHILL FROSTBITE LHR
- Inno3D GEFORCE RTX 3080 12GB ICHILL X3 LHR
- Inno3D GEFORCE RTX 3080 12GB ICHILL X4 LHR
- Inno3D GEFORCE RTX 3080 12GB X3 OC LHR
- Inno3D GeForce RTX 3080 iChill X3 (C30803-106XX-1810VA37)
- Inno3D GeForce RTX 3080 iChill X4, 10 GB GDDR6X (C30804-106XX-1810VA36)
- Inno3D GeForce RTX 3080 Twin X2 OC, 10 GB GDDR6X (N30802-106XX-1810VA34)
- KFA² GeForce RTX 3080 SG 10GB GDDR6X (38NWM3MD99NK)
- Palit GeForce RTX™ 3080 GamingPro (NED30800191A-132AA)
- Palit GeForce RTX™ 3080 GamingPro OC (NED3080S191A-132AA)
- PNY GeForce RTX 3080 XLR8 Gaming EPIC-X RGB (VCG308010TFXMPB)
- PNY GeForce RTX 3080 XLR8 Gaming EPIC-X RGB, 10 GB GDDR6X (VCG308010TFXPPB)
- Zotac Gaming GeForce RTX 3080 AMP Extreme Holo, 10GB GDDR6X, HDMI, 3x DP (ZT-A30800B-10P)
- Zotac Gaming GeForce RTX 3080 AMP Holo, 10GB GDDR6X, HDMI, 3x DP (ZT-A30800F-10P)
- Zotac GAMING GeForce RTX 3080 Trinity (ZT-A30800D-10P)
- Zotac Gaming GeForce RTX 3080 Trinity OC, 10GB GDDR6X, HDMI, 3x DP (ZT-A30800J-10P)
- Gainward GeForce RTX 3080 Ti 12GB Phoenix (471056224-2379)
- Inno3D GEFORCE RTX 3080 TI ICHILL FROSTBITE
- Inno3D GEFORCE RTX 3080 TI ICHILL X3
- Inno3D GEFORCE RTX 3080 TI ICHILL X4
- Inno3D GEFORCE RTX 3080 TI X3
- Inno3D GEFORCE RTX 3080 TI X3 OC
- Palit GeForce RTX 3080 Ti GamingPro
- Zotac Gaming GeForce RTX 3080 Ti AMP Holo (ZT-A30810F-10P)
- Zotac Gaming GeForce RTX 3080 Ti Trinity (ZT-A30810D-10P)
- Zotac Gaming GeForce RTX 3080 Ti Trinity OC
- Zotac GeForce RTX 3080 Ti AMP HoloBlack
- Gainward RTX 3090 Phoenix (1976)
- Gainward RTX 3090 Phoenix GS (2034)
- Galakuro NVIDIA GEFORCE RTX 3090 GG-RTX3090-E24GB/TP
- Galax GeForce RTX 3090 SG 24GB GDDR6X 320-bit DP*3/HDMI/ (39NSM5MD1GNA)
- Inno3D GeForce RTX 3090 Gaming X3, 24 GB GDDR6X (N30903-246X-1880VA37N)
- Inno3D GeForce RTX 3090 iChill X3, 24 GB GDDR6X (C30903-246XX-1880VA37)
- Inno3D GeForce RTX 3090 iChill X4, 24 GB GDDR6X (C30904-246XX-1880VA36)
- KFA² GeForce RTX 3090 SG 24GB GDDR6X 320-bit DP*3/HDMI/
- Palit GeForce RTX™ 3090 GamingPro (NED3090019SB-132BA)
- Palit GeForce RTX™ 3090 GamingPro OC (NED3090S19SB-132BA)
- PNY GeForce RTX 3090 OC XLR8 Gaming Epic-X RGB Triple Fan Edition, 24GB GDDR6X (VCG309024TFXMPB)
- PNY GeForce RTX 3090 XLR8 Gaming EPIC-X RGB, 24 GB GDDR6X (VCG309024TFXPPB)
- Zotac GeForce RTX 3090 Trinity, 24 GB GDDR6X (ZT-A30900D-10P)
Data radiator
L x W x H395 x 124 x 30mm (+/- 3%)
Material cooling finsCopper
Material chambersCopper
Material threadsBrass
G 1/4“ threads2 x for tubes (+ 1x Fillport G1/4“)
For fan size120 mm
Possible fan assembly3 x one-sided / 6 x both-sided
Data cooler and pump
L x W x H130 x 225 x 46 mm
Material cooler bottomChrome plated copper
Material cooler topPMMA
Threads2 x G1/4“
Pump typeDC-LT 2
Pump speed2600 rpm (+/- 10%)
Head of delivery1 m
Maximum flow rate72 L/h
Voltage6-13.5V DC
Power consumption3.2W
MTBF50.000 h
Data liquid
Colorclear
Ingredient 1Destilled water (CAS-number 7732-18-5)
Ingredient 2Glysantin (CAS-number 1017-21-1)
Working temperatures-15 C° / +90 °C
Data quick fasteners
L x D95 x 27 mm
MaterialNylon
For tube size12,7 / 7,6 mm
ColorBlack
Data fittings
L x D straight fitting24 x 18 mm
Quantity straight fittings2x
L x B x H 90° fitting35 x 27 x 17 mm
Quantity 90° fittings2x
Material fittingsBrass
Data tube
Length50 cm
Material tubeTPV (EPDM/PP)
ColorMatt black
Tube size12,7 / 7,6 mm
Hardness grade35 Shore-A to 50 Shore-D
Working temperature-50 to +155 °C
Data fan
Speed0 - 2500 RPM
Static pressure3,17 mm H2O
Air flow rate119,8 m³/h
BearingsSleeve bearing
Fan connector4-Pin PWM
Dimensions120 x 120 x 25 mm
Net weight187 g
Max working temperature60 °C
Radiatorgröße: 360mm
Vorbefüllt: Ja
Sockel: Nvidia GeForce;
Schlauchabmessungen: 12,7/7,6mm
Radiatordicke: 29 - 39mm
WAK Alphacool Core RX 7900XTX/XT Nitro mit Backplate
Alphacool Core RX 7900XTX/XT Nitro with Backplate
€199.98 *
WAK Alphacool MCX 2x Verteiler mit 1m 5/3mm Schlauch
Alphacool MCX 2x distributor with 1m 5/3mm hose
WAK Alphacool Eisblock Aurora GPX-N Acryl Active Backplate 3090/3080 Reference EOL
€49.98 * €86.98 *
KOI Alphacool Eisbaer Aurora HPE Edition 360 CPU AIO
€179.99 *
RAD Alphacool NexXxoS HPE-45 Full Copper 420mm Radiator
€139.98 *
RAD Alphacool ES Aluminium 360 mm T27 - (For Industry only)
WACZ Alphacool Eisblock XPX Pro AM4 Montagekit kompakt
Alphacool Eisblock XPX Pro AM4 Mountingkit compact
Liefertermin: in 2 - 3 Wochen
L14 Yate Loon D14BH-12 mit Stecker (2300rpm) ( 140x140x25mm ) EOL
€4.88 *
€15.39 *
AGZ Alphacool Aurora LED Ring 60mm - Digital RGB
Alphacool Eiswasser Crystal Yellow premixed coolant 1000ml
SEN Alphacool Eisfluegel Durchflussanzeiger Rot 6-11mm - Acryl
Alphacool Eisfluegel flow indicator red 6-11mm - Acryl
SEN Alphacool Eisfluegel Durchflussanzeiger G1/4 eckig - Acetal
Alphacool Eisfluegel flow indicator G1/4 square - acetal
S13 Alphacool HardTube 13/10mm Acryl (PMMA) Klar UV-Blau 60cm - 4er Set (240cm)
Alphacool HardTube 13/10mm Acryl clear UV-Blue 60cm - 4pcs
Content 240 Zentimeter (€3.00 * / 100 Zentimeter)
€7.19 * €16.29 *
Alphacool NexXxos fan mounting screw M3 x 30 mm - 4 pcs
€3.98 *
AGB Alphacool Eisbecher 150mm Acetal Ausgleichsbehälter EOL
Alphacool Eisbecher 150mm Acetal reservoir
€32.97 *
Alphacool HardTube 13/10mm Acryl clear 80cm - 4pcs
Content 320 Zentimeter (€6.24 * / 100 Zentimeter)
SZ Alphacool HardTube Heat Gun Pro 2000W
€17.98 * €24.98 *
LK Phobya Y-Kabel 4Pin PWM 2x 4Pin PWM - Schwarz 10cm
Content 10 Zentimeter (€44.80 * / 100 Zentimeter)
€4.48 *
LK Phobya 4Pin PWM auf 3x 4Pin PWM Verlängerung - Schwarz 40cm
Content 40 Zentimeter (€12.45 * / 100 Zentimeter)
€4.98 *
LZ Lüftergitter für Axiallüfter für 60mm schwarz
€1.49 *
WZS Spritzflasche 250ml PE-LD
€3.59 *
LZ Vibrationsdämpfer 120mm Lüfter Schwarz
€2.39 *
WZS Alphacool Wasser-Filter Acryl EOL
€18.79 *
