Alphacool MCX 2x distributor with 1m 5/3mm hose
- Article no.: 13041
- EAN: 4250197130417
- Weight: 0,01 kg
*1Flexibility and design with optimal performance! The Alphacool MCX 2x distributor made of acetal offers various areas of application.
It opens up the possibility to easily integrate Alphacool's active backplates or MCX water coolers into the water circuit. This allows e.g. RAM devices and voltage converters on graphics cards to be cooled more efficiently. The integration of the MCX 2x distributor into the water circuit is uncomplicated via 2 G1/4" connections with internal thread. Alphacool's connections from the Eiszapfen series are recommended here. A transparent 5/3mm PVC hose is included in the delivery. With a length of 1m, the hose offers sufficient leeway for a flexible installation of the distributor.
| Technical data | |
| L x W x H distributor | 30 x 29 x 18 mm |
| Material distributor | acetal |
| Length hose | 1 m |
| Hose size | 5/3mm |
| Material hose | PVC |
| Connections | 2x G 1/4 inner thread | 2x hose nozzles 3 mm screwed in |
| Max. Thread length G 1/4 Connections | 5.5 mm |
| Pressure tested (without clamps) | 3.2 bar |
| Pressure tested (with clamps) | 5.2 bar |
| Weight | 28 g |
| Color | black |
