Alphacool Core Thermal Pad Soft 9W/mk 120x20x1mm
  • 13426
  • 4250197134262
  • 0,022 kg
€5.68 * €9.98 * (43.09% Saved)
Content: 24 cm² (€0.24 * / 1 cm²)
€4.28*
€69.98*
13416 Alphacool Core Thermal Pad Soft 9W/mk 100x100x1mm
€11.78*
13421 Alphacool Core Thermal Pad Soft 9W/mk 40x40x1mm
€4.78*
13427 Alphacool Core Thermal Pad Soft 9W/mk 120x20x1,5mm
€6.99*
Alphacool's performance thermal pad can be used to cool electronic components of all kinds where... more
Increased service life!
Versatile use!
Technical data thermal pad
Dimensions (L x W x H)120 x 20 x 1mm
Thermal Conductivity (ASTM D5470)9.0 W/mK (±10%)
Hardness (ASTM D2240)50 (Shore 00) (±15)
Working temperature-50 to ~180°C
Volume Resistance (ASTM D257)1×10¹² Ohm-m
Dielectric Breakdown Voltage (ASTM D149)≥8 KV/mm
Density (ASTM D792)3.2 g/cm³ (±10%)
Elongation (ASTM D412)40%
Flame Rating (UL 94)V-0
Colorpink
43%
Alphacool Core Thermal Pad Soft 9W/mk 120x20x0,5mm
Content 24 cm² (€0.19 * / 1 cm²)
€4.58 * €7.98 *
42%
Content 24 cm² (€0.29 * / 1 cm²)
€6.99 * €11.98 *
38%
Alphacool Core Thermal Pad Soft 9W/mk 40x40x2mm
Content 16 cm² (€0.39 * / 1 cm²)
€6.18 * €9.98 *
Delivery date: in 7 - 8 weeks
63%
€1.58 * €4.28 *
Alphacool 4-Pin Molex to Lumberg 10cm
Content 10 Zentimeter (€44.80 * / 100 Zentimeter)
€4.48 *
49%
Alphacool Core Thermal Pad Soft 9W/mk 100x100x2mm
Content 100 cm² (€0.19 * / 1 cm²)
€18.78 * €36.99 *
Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1,5mm
Content 24 cm² (€0.23 * / 1 cm²)
€5.58 * €7.98 *
33%
Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1mm
Content 24 cm² (€0.20 * / 1 cm²)
€4.68 * €6.99 *
43%
Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x0,5mm
Content 100 cm² (€0.07 * / 1 cm²)
€6.88 * €11.98 *
€4.48 *
€1.89 *
50%
Alphacool Apex Soft thermal pad 11W/mk 2x 120x20x1mm
Content 48 cm² (€0.20 * / 1 cm²)
€9.58 * €18.98 *
€3.97 *
20%
€3.97 * €4.97 *
