Alphacool Eiswolf 2 AIO - 360mm RTX 4090 Strix + TUF with Backplate
- Article no.: 13494
- EAN: 4250197134941
- Weight: 4,955 kg
Fullcover Waterblock?
Chrome-plated copper
Pump
Fittings and Tubing
Expandability
Lighting and fans
NexXxoS Radiator
Technical note!
- Asus ROG Matrix GeForce RTX 4090 Platinum, ROG-MATRIX-RTX4090-P24G-GAMING, 24GB GDDR6X (90YV0ID7-M0NM00)
- Asus ROG Strix GeForce RTX 4090 OC, ROG-STRIX-RTX4090-O24G-GAMING, 24GB GDDR6X (90YV0ID0-M0NA00)
- Asus ROG Strix GeForce RTX 4090, ROG-STRIX-RTX4090-24G-GAMING, 24GB GDDR6X (90YV0ID1-M0NA00)
- Asus TUF Gaming GeForce RTX 4090 OC, TUF-RTX4090-O24G-Gaming, 24GB GDDR6X (90YV0IE0-M0NA00)
- Asus TUF Gaming GeForce RTX 4090, TUF-RTX4090-24G-GAMING, 24GB GDDR6X (90YV0IE1-M0NA00)
Technical data radiator | |
Material threads | Brass |
For fan size | 120 mm |
Dimensions (L x W x H) | 220,90 x 166,60 x 46,10 mm |
Threads | 2 x G1/4“ |
Pump type | DC-LT 2 |
Head of delivery | 1 m |
Maximum flow rate | 72 L/h |
Voltage | 6-13.5V DC |
Power consumption | 3.2W |
MTBF | 50.000 h |
Technical data liquid | |
Color | clear |
Material | Nylon |
Color | Black |
Technical data fittings | |
Quantity 90° fittings | 2x |
Material fittings | Brass |
Technical data tube | |
Length | 50cm |
Color | Matt black |
Tube size | 12,7 / 7,6mm |
Technical data fan | |
Speed | 0 - 2500 RPM |
Air flow rate | 119,8 m³/h |
Bearings | Sleeve bearing |
Fan connector | 4-Pin PWM |
Net weight | 187g |
Vorbefüllt: | Ja |
Radiatorgröße: | 360mm |
Radiatordicke: | 29 - 39mm |
Sockel: | Nvidia GeForce; |
