  • 17376
  • 4250197173766
  • 0,149 kg
€36.98 *
Content: 6 Stück (€6.16 * / 1 Stück)
Design: HardTube screw-on nozzle 13mm
This connection has a 1/4" external thread on one side. HardTubes with an external diameter of 13mm can be screwed on the other side.
  • Material: Brass
  • Color: Chrome
dimension
  • Diameter: 21mm
  • Height: 16mm
Scope of delivery
  • 1x Alphacool Eiszapfen 13mm HardTube screw-on nozzle G1/4 for acrylic brass tubes - Chrome Sixpack
Here you will find an interactive overview of all Alphacool connections.
€20.98 *
€25.98 *
Alphacool Eiszapfen angled adaptor 90° rotatable G1/4 AG to G1/4 IG - 4pcs Set Chrome
Content 4 Stück (€7.00 * / 1 Stück)
€27.98 *
Alphacool HardTube 13mm OD 90° brass 20/40cm chrome
