Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x3mm
  • 13411
  • 4250197134118
  • 0,029 kg
Content: 16 cm² (€0.56 * / 1 cm²)
€4.28*
€69.98*
13406 Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x3mm
€32.97*
13407 Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x0,5mm
€3.97*
13414 Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1,5mm
€7.98*
Alphacool's performance thermal pad can be used to cool electronic components of all kinds where... more
Increased service life!
Versatile use!
Technical data thermal pad
Dimensions (L x W x H)40 x 40 x 3mm
Thermal Conductivity (ASTM D5470)6.2 W/mK (±10%)
Hardness (ASTM D412)50 (Shore 00) (±15)
Working temperature-50 to ~150°C
Volume Resistance (ASTM D257)1×10¹³ Ohm-m
Dielectric Breakdown Voltage (ASTM D149)6 KV/mm (±10%)
Density (ASTM D792)3.1 g/cm³ (±10%)
Elongation (ASTM D412)50%
Flame Rating (UL 94)V-0
Colorblue
€1.19 *
WÄM Alphacool Wärmeleitpad für NexXxoS GPX 3W/mk 30x30x3mm yellow marked PE Bag (4 Stück)
Alphacool thermal pad for NexXxoS GPX 3W/mk 30x30x3mm yellow marked PE Bag (4 pieces)
Content 36 cm² (€0.11 * / 1 cm²)
€3.78 *
Content 24 cm² (€0.33 * / 1 cm²)
Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1mm
Content 24 cm² (€0.29 * / 1 cm²)
€6.99 *
Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x2mm
Content 16 cm² (€0.44 * / 1 cm²)
€6.99 *
WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 40x40x1,5mm
Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x1,5mm
Content 16 cm² (€0.37 * / 1 cm²)
€5.99 *
Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x1mm
Content 16 cm² (€0.31 * / 1 cm²)
€4.97 *
Alphacool y-splitter 4-Pin to 4x 4-Pin PWM 15cm white
Content 15 Zentimeter (€26.47 * / 100 Zentimeter)
€3.97 *
€3.78 *
€2.58 *
Alphacool Core Thermal Pad Soft 9W/mk 120x20x1,5mm
Content 24 cm² (€0.50 * / 1 cm²)
€11.98 *
Alphacool Core Thermal Pad Soft 9W/mk 40x40x3mm
Content 16 cm² (€0.81 * / 1 cm²)
Alphacool Core Thermal Pad Soft 9W/mk 40x40x2mm
Content 16 cm² (€0.62 * / 1 cm²)
Content 100 cm² (€0.33 * / 1 cm²)
€32.97 *
Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x2mm
€24.98 *
WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 100x100x1mm
Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x1mm
Content 100 cm² (€0.17 * / 1 cm²)
€6.99 *
Content 25 cm² (€0.28 * / 1 cm²)
€6.99 *
WÄM Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 50x50x3mm
21%
€33.97 * €42.98 *
€1.48 *
