  • 13036
  • 4250197130363
  • 0,017 kg
Content: 4 Gramm (€1,070.00 * / 1000 Gramm)
12856 Alphacool Eisschicht Light thermal pad - 7W/mK 100x100x0,5mm
€5.38*
12859 Alphacool Eisschicht Light thermal pad - 7W/mK 100x100x1,5mm
€8.48*
The Alphacool Apex Thermal Grease is intended for all users who want to achieve the optimum... more
Application
Properties
Alphacool's Apex Thermal Grease has an extremely high thermal conductivity, making it one of the best performing thermal pastes on the market. Only liquid metal thermal pastes offer better thermal conductivity. The Apex Thermal Grease is delivered in a 4g applicator with screw cap. The amount of thermal paste is sufficient for several applications and can be stored in the applicator protected from drying out. In addition, Apex Thermal Grease is non-conductive and non-caustic. If a small amount of paste is spilled during application, damage to the hardware is highly unlikely.
Range of uses
Volatilization Rate (24H@200°C)%less than 0.5
Density (g/cc)3.2 (Test method ASTM D792)
Viscosity (mPa.s)150~200*10³ (Test method ASTM D2196)
Continuous Using Temperature (°C)-40°C to 120°C
Breakdown Voltage (V/mil)250 (Test method ASTM D149)
Thermal Impedance (°C in 2/W)0.1 +/- 0.01 (Test method ASTM D5470)
Max. working pressure (psi)40
Colorgray
Quantity4g
Safety notes
  • Rinse gently with water for a few minutes.
  • In case of fire: Do not inhale explosion and fire gases.
€4.97 *
20%
€3.97 * €4.97 *
21%
€33.97 * €42.98 *
22%
€46.98 * €59.98 *
61%
€5.78 * €14.98 *
47%
€15.78 * €29.98 *
€1.78 *
Delivery date: in 5 - 6 days
38%
WÄM Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 50x50x3mm
Content 25 cm² (€0.20 * / 1 cm²)
€4.97 * €7.98 *
21%
SZ Schlauchabschneider
hose cutter
€4.97 * €6.30 *
43%
€3.97 * €6.99 *
€6.99 *
€29.98 *
