Alphacool Eistools assembly gloves size XL - Black
ZSO Alphacool Eistools Montagehandschuhe Größe XL - Black EOL
  • 90374
  • 4250197136792
  • 0,1 kg
€1.48 * €3.18 * (53.46% Saved)
SZ Alphacool Acrylic Tube Double Bending Tool 12-14mm and 16mm - Black
€17.98*
WZS Alphacool Eistools Crimping Kit
€72.98*
€20.98*
WZS Alphacool Eistools Modding Cutter - Black EOL
€9.98*
The Alphacool ice hands are a must for every hobbyist and modder. Thanks to a rubber coating,... more
The Alphacool ice hands are a must for every hobbyist and modder. Thanks to a rubber coating, tools, hard tubes and water cooling connections lie safely in the hand. They protect the hands from injuries and also temporarily against heat when bending hard tubes or dust when cutting metals and borosilicate glass tubes.
The top of the gloves is made of breathable material. Excessive sweating of the hands in the gloves is prevented by a thin and elastic material on the top. The wide elastic band, which extends over the wrist, ensures that the glove fits securely.
17%
€37.98 *
€41.98 * €59.98 *
€28.98 *
€41.98 *
