Yate Loon D80SM-12 mit Stecker (2500rpm) ( 80x80x15mm )
- Article no.: L80
- EAN: 4049469047573
- Weight: 0,07 kg
New fan from Yate Loon. Strong airflow and super-quiet operation speak for this 80mm axial fan with a bronze bearing. The fan can be connected to the PSU via a Molex plug (with adaptor, sold separately) or directly to the Mainboard. The fan is ideal for the super silent operation when operated at <7V. Thanks to the extra long connection cable of approx. 60cm th fan can also be used in very large cases (e.g. Server or Big-tower) and still be properly wired without using cable extensions.
An absolute highlight of this fan is the slim design! Being only 15mm thick it can easily be installed even in very small cases. Additionally the fan also features very good Airflow that is yet to be matched in its class.
Technical data:
Dimensions: 80x80x15mm
Nominal voltage: 12V
Nominal speed: 2500rpm
Airflow: 24CFM
Noise level: 30 dB(A)
Power consumption: 1,2W
With 3Pin Molex plug, 60cm cable and rpm signal
Nennspannung: | 12V DC |
LED: | nicht vorhanden |
Lautstärkebereich: | 30 - 49,9 dB(A) |
Stromanschluss: | 3Pin |
Luftförderbereich: | 0 - 49 m³/h |
Größe: | 80mm |
Leistungsaufnahme: | 1,2W |
Hersteller: | Yate Loon |
RPM Signalübertragung: | Nein |
Nenndrehzahl: | 2500 U/min |
Abmessungen: | 80 x 80 x 15mm |
Farbe Rahmen: | schwarz |
Luftförderleistung: | 24 m³/h |
Lautstärke: | 30 dB(A) |
Farbe Rotor: | schwarz |
