Alphacool Aurora Acryl X4 D-RAM water cooler
- Article no.: 17467
- EAN: 4250197174671
- Weight: 0,313 kg
The Alphacool Aurora Acryl X4 D-RAM water cooler, in combination with the Alphacool D-RAM modules (manufacturer no. 17268), offers the perfect cooling for your RAM. The digital RGB LED Aurora lighting also offers the ideal extension to your Alphacool Aurora products.
Quality and design
The cooler itself consists of a solid 4 mm thick copper block that has of course been nickel-plated. The design is now identical to all new Aurora products from Alphacool. Since a pure acrylic block is not particularly attractive, we have added a nice black frame. This makes the cooler look more interesting and fits harmoniously into the Aurora range.
The LED strip with the addressable digital LEDs is embedded into the side of the RAM cooler and sits flush with the cooler. There is nothing sticking out here.
Digital RGB lighting
The aRGB LED strip has six digital RGB LEDs. Enough to illuminate the entire RAM cooler evenly. Each LED can be controlled separately with a corresponding controller. This makes a variety of effects possible. Especially in combination with other Alphacool Aurora water cooling components, effects can be created across the entire PC. For example, a surrounding lighting effect with several color changes or a pulsating effect, also with different colors. The possibilities are almost unlimited.
Intelligent aRGB connection
The addressable digital RGB LEDs are connected via the familiar 3-pin ADD connector. A suitable female to male connector for the ADD header is also included. This should make it possible to operate the Alphacool Aurora Acryl X4 D-RAM water cooler on all common motherboards with an aRGB connector without any problems. If you want to use several Alphacool Aurora products, you can be happy about the integrated Y-adapter on the cable. This saves you having to buy various adapter cables and allows you to connect all Aurora products together quite easily. In the worst case, only extension cables are needed.
Assembly is very simple
The Alphacool Aurora Acryl X4 D-RAM cooler is simply screwed onto the Alphacool D-RAM modules. The screws should be inserted into the respective openings of the Aurora Acryl X4 D-RAM water cooler before assembly. A little of the included thermal paste is then applied to the D-RAM modules so that the heat is transferred perfectly. The Aurora X4 RAM cooler is then simply placed on top and screwed in place.
Technical data:
- W x D x H: 128 x 45 x 19 mm
- Net weight: 258 g
- Maximum working temperature: 60 °C
- Cooler material: Nickel-plated copper
- Lid material: acrylic
- Connections: 2 x G1/4“
- Power connector: Digital RGB 3-Pin 5V
- Pressure tested: 1.5 bar
- Certificates: CE, FC, ROHS
Download manual PDF: Alphacool Aurora Acryl X4 D-RAM cooler
Download data sheet PDF:Alphacool Aurora Acryl X4 D-RAM cooler
Delivery date: in 7 - 8 weeks
Delivery date: in 2 - 3 weeks
