Alphacool Laing DDC310 - Single Edition - silver
  • 13178
  • 4250197131780
  • 0,345 kg
€69.98 *
PUZ Alphacool Eisdecke Laing DDC Acrylic Top V.2
€29.98*
PUZ Alphacool Eisdecke DDC/D5 expansion tank individually for Alphacool Eisdecke
€29.98*
Get 10% off during Alphacool Black Friday Week. The discount will be visible in your shopping cart.
*1 Offer valid until 01/12/2025
Alphacool's new Low Noise Edition of the Laing DDC for absolute silence! The Laing DDC pump... more
The Laing DDC pump is one of the best known pumps in the watercooling industry. Recently we have been working with Laing to take the DDC to the next level. The new Laing DDC310 was designed with a perfect balance of power and silence in mind. Unlike other versions with the plastic base we have revised the design with new superbly tuned brass housing which aids the pumps cooling and guarantees longer life especially when placed in areas with limited airflow.
This new housing promises a longer life of the pump. Through the cooling fins and air flow as well as an internal thermal pad attached directly to the pump board maximum cooling is achieved.
Another feature is the included decoupling option. If a pump top with a M4 threaded mounting hole, such as the Alphacool Laing DDC Acetal top is present. The special M4 screws can be screwed directly into the decoupling set and then into the case.
The pump also comes as standard with an anti-vibration mounting system . Available in black nickel and silver nickel.
This pump should be the first choice for your watercooling system.
Dimensions (L x W x H)62 x 62 x 30mm
MaterialStainless steel, Carbon (FH821Z2), Ceramic (Al2O3 99,5%), Luranyl KR 2403 GW T4 (PPE+PS) , Fortron 1140L4 (PPS)
Weight170g
Speed3250 rpm
Max power consumption8W
Voltage12V DC
Power connector4-Pin Molex
Tacho-Signalyes (3-Pin Molex)
Max. working temperature ambiente10°C - 50°C
Max. working temperature water10°C - 60°C
Max. head of pump2,28m
Max. flow200 L/h
Max. pressure [bar]0,2
Colorsilver
RevisionDDC4.CF-XTXXWX-01 BP54
Warranty: 5 years
Dimensions: 62 x 62 x 30mm
Maximum discharge head: Good (2 to 4m), Standard (less than 2m)
Maximum system temperature: 60°C
Maximum flow: 200 l/h, 480 l/h
Color: Black
Tension: 12V DC
Power connection: 4Pin
Gewicht: 170g
Water outlet: Unavailable
Water inlet: Unavailable
Approved liquids: Water/glycol mixture
Power consumption: 8W
Material: Aluminiumoxid;Hartkohle;Messing;
27%
PUM Laing DDC-Pumpe 12V DDC-1T Plus PHT EOL
Laing DDC pump 12V DDC-1T Plus
€64.99 * €89.23 *
34%
Laing DDC pump 12V DDC 4.2
€66.99 * €101.13 *
Content 6 Stück (€5.00 * / 1 Stück)
€29.98 *
Content 320 Zentimeter (€6.87 * / 100 Zentimeter)
€21.98 *
63%
€1.58 * €4.28 *
WAC Alphacool ES 1 1U
Alphacool ES 1 1U
€125.98 *
WAC Alphacool Core 1 White
€109.98 *
€99.98 *
20%
Content 2 Stück (€12.80 * / 1 Stück)
€25.59 * €31.98 *
€6.28 *
14%
AGB Alphacool Rise Flat Reservoir DDC EOL
€89.98 * €104.98 *
20%
