  • 18541
  • 4250197185417
  • 0,014 kg
€0.99 * €4.89 * (79.75% Saved)
Content: 100 Zentimeter
This cable is a simple solution to connect motherboards from ASUS, Gigabyte or MSI to your RGB... more
This cable is a simple solution to connect motherboards from ASUS, Gigabyte or MSI to your RGB lighting. This way you can easily synchronize and control your RGB lighting via your motherboard's software!
Scope of delivery
  • 1x Alphacool RGB 4-pin LED adapter cable for motherboards 100cm - Black
€1.48 *
54%
Alphacool RGB 4-pin LED adapter cable for motherboards - Black 50cm
Content 50 Zentimeter (€3.96 * / 100 Zentimeter)
€1.98 * €4.28 *
51%
Alphacool Eis-Matrix connection cable to 4-pin RGB - 10cm
Content 10 Zentimeter (€9.80 * / 100 Zentimeter)
€0.98 * €1.98 *
83%
Alphacool Y-cable RGBW 5-pin to 3x 5-pin incl. connector - black 30cm
Content 30 Zentimeter (€3.30 * / 100 Zentimeter)
€0.99 * €5.89 *
Alphacool Y-cable RGB 4-pin to 3x 4-pin incl. connector - black 60cm
€2.98 *
€5.48 *
86%
KAB Alphacool Y-Kabel RGBW 5pol auf 3x 5pol inkl. Stecker - Schwarz 60cm EOL
Alphacool Y-cable RGBW 5-pin to 3x 5-pin incl. connector - black 60cm
Content 60 Zentimeter (€1.65 * / 100 Zentimeter)
€0.99 * €6.89 *
60%
WACZ Alphacool Aurora XPX RGB Frame - Black PHT EOL
€3.99 * €9.95 *
€28.98 *
€2.28 *
Delivery date: in 5 - 6 weeks
47%
€15.78 * €29.98 *
€6.99 *
