Alphacool Eis-Matrix connection cable to 4-pin RGB - 10cm
  • 18603
  • 4250197186032
  • 0,004 kg
€0.98 * €1.98 * (50.51% Saved)
Content: 10 Zentimeter (€9.80 * / 100 Zentimeter)
KAB Alphacool RGB 4-pin LED adapter cable for motherboards - Black 100cm EOL
€0.99*
SZ Alphacool Aurora HardTube LED Ring 13mm Deep Black - RGB
€7.98*
WACZ Alphacool Aurora XPX RGB Frame - Black PHT EOL
€3.99*
Finally here! The RGB connection cable for your Alphacool Eis-Matrix. The included connector... more
Finally here! The RGB connection cable for your Alphacool Eis-Matrix. The included connector serves as an adapter to connect your RGB products male or female to your Eis-Matrix.
  • Cable length: 10cm
  • Pin length connector: 4mm
Alphacool Y-cable RGB 4-pin to 3x 4-pin incl. connector - black 60cm
€2.98 *
54%
Alphacool RGB 4-pin LED adapter cable for motherboards - Black 50cm
Content 50 Zentimeter (€3.96 * / 100 Zentimeter)
€1.98 * €4.28 *
86%
KAB Alphacool Y-Kabel RGBW 5pol auf 3x 5pol inkl. Stecker - Schwarz 60cm EOL
Alphacool Y-cable RGBW 5-pin to 3x 5-pin incl. connector - black 60cm
Content 60 Zentimeter (€1.65 * / 100 Zentimeter)
€0.99 * €6.89 *
€0.99 * €4.89 *
54%
€1.98 * €4.28 *
€1.48 *
€2.98 *
56%
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - White (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
63%
€1.58 * €4.28 *
€5.99 *
€1.68 *
€1.48 *
WAGZ Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 50x50x2mm
Content 25 cm² (€0.28 * / 1 cm²)
€6.99 *
€5.48 *
Alphacool AGB Universal Mount Clip-On 50mm - Black 2 pieces
Content 2 Stück (€2.24 * / 1 Stück)
€4.48 *
LK Alphacool Y-Splitter 4-Pin auf 4x 4-Pin PWM 60cm weiß
Alphacool y-splitter 4-Pin to 4x 4-Pin PWM 60cm white
€5.99 *
Alphacool y-splitter 4-Pin to 4x 4-Pin PWM 30cm white
Content 30 Zentimeter (€15.60 * / 100 Zentimeter)
€4.68 *
Delivery date: in 11 - 12 weeks
€3.78 *
Alphacool y-splitter 4-Pin to 2x 4-Pin PWM 30cm white
€2.98 *
Alphacool fan cable 4-pin to 4-pin extension 60cm white
€2.98 *
Alphacool fan cable 4-pin to 4-pin extension 30cm white
€2.58 *
