Phobya Adapter USB (5V) Extern auf 3Pin Lüfter - Schwarz 30cm
- Article no.: LK
- EAN: 4049469146405
- Weight: 0,012 kg
With this cable it is possible to operate a fan simply via an USB connection. The voltage is just right to operate a fan quietly and with a pleasant airflow. When looking into operating a fan outside of the system enclosure, and the hot summer months are coming up, this is the perfect solution to quickly make a computer fan into a desk fan!
Sleeving
This cable is not only practical, it is also optically appealing, The surrounding mesh, also called sleeve, which is surrounding the cable itself offers the advantages that every Pro-modder is looking for: A completely unique look, even of the cables in the system! Special attention was paid to the combination of cable connectors, sleeve and heatshrink which were used to ensure great design and a unique as well as elegant look.
The idea behind these cables
Technical specifications
- Cable length: 30cm
- Colour: Black
- Connector type: USB to 3-Pin fan connector
Extent of delivery
- 1x Phobya adaptor USB (5V) external to 3-Pin fan 30cm - black
1. Seite: | 1x 3Pin Molex |
2. Seite: | 1x 3Pin Molex |
Bauform: | Adapter |
Sleeving: | schwarz |
Hersteller: | Phobya |
