- Article no.: 11609
- EAN: 4250197116091
- Weight: 0,226 kg
The Alphacool Strong Guy is a professional deburrer for HardTubes and brass tubes. When using HardTubes, it is essential that the ends of the tubes are cleanly deburred. Sharp edges and unclean cuts can damage the seals in the HardTube connections. This can cause the connections to become leaky and liquid to escape.
The Alphacool Strong Guy is made entirely of metal and therefore fits very well in the hand. It offers two sides for deburring, namely for the outer edge and the inner edge of the HardTube or the brass tube. With just a few turns of the HardTube on the sharp blades, clean cutting edges can be created that can glide gently along the seals when inserted into the water cooling connection without damaging them.
Material: Steel
Dimensions: 57 x 52 mm
