Alphacool Apex Heat Gun with LCD 2000W 80-650°C
  • 10178
  • 4250197101783
  • 0,901 kg
€39.98 *
€10.98*
ZSO Alphacool Eiskoffer - Multi-Bending Feeder Large
€26.98*
SZ Alphacool ice case - bending plate
€20.98*
S16 Alphacool Ice Tube 14/11mm PETG HardTube 80cm - Set of 4 (320cm)
€25.98*
Alphacool's versatile Apex Heat Gun is the perfect tool for every water cooling enthusiast and... more
Alphacool's versatile Apex Heat Gun is the perfect tool for every water cooling enthusiast and deserves a permanent place in the toolbox. With the help of the Heat Gun, laying and bending hard tubes is child's play!
Full control
Temperature and airflow can be easily adjusted using push buttons on the top of the heat gun. When activated, the large LCD display shows the current temperature and the strength of the airflow.
Security
Equipped with three rubber feet on the back, the heat gun can be placed upright so that both hands are free while working. The rubber feet give it a stable stand and, among other things, facilitate the cooling process after work is done. It has various safety functions that speed up the cooling process. After switching off, the fan continues to run, the excess heat in the device is dissipated and the heating coil can cool down evenly. This process significantly extends the service life of the heat gun.
Versatile
The delivery includes 3 nozzles for a variety of applications. In addition to working on hard tubes in a water cooling system, Alphacool's Apex Heat Gun is a useful addition to any toolbox. The following applications are also possible:
  • Shrinking heat shrink tubing
  • Forming articles made of acrylic, PVC or polystyrene
  • Welding of thermoplastic polymers, tarpaulins and films
  • Soldering tin or loosening solder joints
  • Removal of oil paints, varnishes and plastic plaster
maintenance
To ensure safe and efficient operation, the ventilation slots on the device must always be kept clean. Any necessary repairs may only be carried out by an authorized service center for power tools.
L x W x H 26.5x25x9cm
Tension 230V AC
frequency 50/60Hz
Max. power consumption 2000W
Electricity 8A
Temperature range 80-650 °C
Airflow 15-35.7 m3 /h
Weight with cable 0.8kg
Cable length 1.8m
Color Blue
Download:
Datasheet PDF
€28.98 *
€37.98 *
€20.98 *
€26.98 *
€39.98 *
€25.98 *
€38.98 *
