Phobya 4Pin PWM Verlängerung - Schwarz 30cm
- Article no.: LK
- EAN: 4049469100032
- Weight: 0,01 kg
An extension for a 4-Pin PWM connector.
As fan control via the Mainboard with a PWM fan is much more affordable than a fan controller, this cable is perfect to give more flexibility.
The extension cable is sleeved with a black mesh which additionally protects the cable and looks great! This further expands the lifespan of the cable. The ends towards the connectors are fixated with heatshrink for a clean finish.
Sleeving:
The idea behind these cables:
Technical specifications:
Length: 30cm
Colour: Black
4-Pin PWM
Extent of delivery:
1x Phobya extension 4-Pin PWM 30cm - black
This product has been reviewed for you:
Aquainfos
Tech-Review
1. Seite: | 1x 4Pin PWM |
Sleeving: | schwarz |
Hersteller: | Phobya |
2. Seite: | 1x 4Pin PWM |
Bauform: | Verlängerung |
Liefertermin: in 2 - 3 Wochen
