Phobya 4Pin PWM auf 3x 4Pin PWM Verlängerung - Schwarz 40cm
  • LK
  • 4049469125417
  • 0,019 kg
€4.98 *
Content: 40 Zentimeter (€12.45 * / 100 Zentimeter)
This cable is designed to connect multiple fans to one PWM socket, e.g. on a Mainboard, to allow... more
This cable is designed to connect multiple fans to one PWM socket, e.g. on a Mainboard, to allow control and monitoring,
Important: To allow precise monitoring and control of the fans, they must be identical respectively from the same series. Different fans can also be used, but the monitored speed values will not be accurate.
Please note: Connecting multiple fans to one socket may exceed the power envelope of the socket, damaging the controller unit!
Sleeving:
The idea behind these cables:
Technical specifications:
Length: 40cm - 20cm, 10cm and 10cm
Color: Black sleeve
Connectors:
1x 4-Pin PWM male
3x 4-Pin PWM female
Extent of delivery:
1x Phobya 4-Pin PWM to 3x4-Pin PWM extension 40cm - black
This product has been reviewed for you:
Aquainfos
Tech-Review
Overclockingstation
Please note the difference between a 4-Pin power connector (Molex) and a 4-Pin fan connector (PWM)
Sleeving: schwarz
Hersteller: Phobya
Bauform: Y-Kabel
1. Seite: 1x 4Pin PWM
2. Seite: 3x 4Pin PWM
LK adapter 4Pin (12V) to 3Pin (7V)
€1.19 * €2.09 *
€1.19 *
Content 30 Zentimeter (€2.17 * / 100 Zentimeter)
€0.65 *
€5.68 *
SEN Alphacool Eisfluegel Durchflussanzeiger G1/4 eckig - Acetal
Alphacool Eisfluegel flow indicator G1/4 square - acetal
LK Phobya Y-Kabel 4Pin PWM 2x 4Pin PWM - Schwarz 10cm
Content 10 Zentimeter (€44.80 * / 100 Zentimeter)
€4.48 *
€23.98 *
WZS Alphacool Wasser-Filter Acryl EOL
€18.79 *
RAD Alphacool NexXxoS HPE-45 Full Copper 420mm Radiator
€139.98 *
RAD Alphacool NexXxoS HPE-45 Full Copper 360mm Radiator
€109.98 * €124.99 *
Liefertermin: in 10 - 11 Tagen
€2.98 *
RAD Alphacool NexXxoS HPE-30 Full Copper 360mm Radiator
€104.98 *
AGZ Alphacool Aurora LED Ring 60mm - Digital RGB
SZ Alphacool Eiskoffer Basic - bending kit
€99.98 *
SZ Alphacool Eiskoffer - measuring kit
€24.98 *
Alphacool Eisrohr 16/13mm PETG HardTube 60cm - 4pcs
Content 240 Zentimeter (€7.91 * / 100 Zentimeter)
Alphacool Eisrohr 16/13mm Acryl (PMMA) HardTube satin 80cm - 4pcs
Content 320 Zentimeter (€11.56 * / 100 Zentimeter)
€36.98 *
SEN Alphacool Eisfluegel Durchflussanzeiger Rot 6-11mm - Acryl
Alphacool Eisfluegel flow indicator red 6-11mm - Acryl
ANZ Alphacool Eiszapfen Verschlussschraube G1/4 - Deep Black
Alphacool Eiszapfen screw plug G1/4 - deep black
€2.98 *
€26.98 *
ANF Alphacool HF Verlängerung G1/4 auf G1/4 20mm - Deep Black
Alphacool HF extension G1/4 to G1/4 20mm - Deep Black
€2.78 *
SZ Alphacool HardTube Heat Gun Pro 2000W
€17.98 * €24.98 *
ANK Alphacool HF Schottverschraubung G1/4 - Deep Black
Alphacool HF bulkhead connector G1/4 - deep black
€5.98 *
