Alphacool NexXxoS HPE-45 Full Copper 360mm Radiator
  • 14440
  • 4250197144407
  • 1,415 kg
  • 10
€121.98 *
€6.98*
ANS Alphacool Eiszapfen 13/10mm screw-on nozzle 90° rotatable G1/4 - Deep Black
€8.98*
PUM Alphacool Laing DDC310 - Complete Edition Ice Cover - silver/acrylic
€83.98*
13000 Alphacool Eisbaer Pro Aurora (Solo) - Digital RGB
€89.98*
€6.98*
For more than a decade, Alphacool has dominated the market with the NexXxoS Full Copper radiator... more
Connection options & mounting
Safety first
Patented screw plugs
1x Alphacool NexXxoS HPE-45 Full Copper 360mm Radiator, black
12x M3x5 case mounting screws
12x M3x30 fan screws
4x screw plugs
1x Allen key
1x plug tool
Technical data radiator
L x W x H391.5 x 124 x 45 mm (±3 %)
Quantity of cooling channels28
Material threadsbrass
Threads4x G 1/4 IN/OUT & 1x Fill-/Drainport G 1/4 (max. 5 mm thread length)
Possible fan size120 mm
Possible fan assembly3x one-sided / 6x both-sided
Thread size fan mountingM3
Pressure tested0.8 bar
Fin density16 FPI
Weight1248 g
Warranty: 10 years
