Alphacool Aurora LED Ring 60mm - Digital RGB
- Article no.: 15363
- EAN: 4250197153638
- Weight: 0,028 kg
The new Aurora expansion tank LED rings with addressable RGB connection offer you the best modding options to control and stage your system like a professional.
Optics at its finest
The new aRGB technology gives you the option to illuminate your entire system with different color modes. This makes your gaming system a real eye-catcher at any LAN party or simply at home.
Alphacool offers compatibility
With the new LED rings from Alphacool you can illuminate all containers with an outer diameter of 60mm and thus equip a variety of different systems, just as you want.
The power connection is made via a 3-pin aRGB connector, which is connected to your controller or directly to the mainboard. Alphacool offers the Eiscontrol Addressable RGB Controller for all digital RGB products. Alphacool products are compatible with Asus Aura Sync, Gigabyte RGB Fusion 2.0 and many other hardware manufacturers.
Compatible with all tube expansion tanks with a diameter of 60 mm!
Inner diameter: 60 mm
Outer diameter: 68 mm
Thickness: 19 mm
LEDs: 11 x Digital RGB
Connector: 3-pin aRGB 5V
Delivery date: in 6 - 7 weeks
