Alphacool expansion tank individually for DC-LT pumps
  • 13140
  • 4250197131407
  • 0,12 kg
The optimal addition to the Alphacool DC-LT Plexi attachment including the Alphacool DC-LT... more
The optimal addition to the Alphacool DC-LT Plexi attachment including the Alphacool DC-LT ceramic 12 volt pump.
The Alphacool expansion tank individually for DC-LT pumps is another module for expanding and improving the Alphacool DC-LT ceramic 12 volt pump. The basis here is the already converted pumps with an Alphacool DC-LT Plexi attachment. These can now be fitted with an expansion tank in just a few simple steps. Simply place the tank on the attachment with the seal included in the delivery, tighten the 4 screws included in the delivery at the corners, and you're done!
Another 1/4" threaded opening has been installed on the side. This can be used as an inlet opening or for a lighting module.
Technical data:
Material: Röhm Plexiglas GS / brass
Colour: transparent / black
Dimensions (LxWxH): 49 x 49 x 56mm (without connections, without pump)
Weight: 141g
Connection thread size: 1x 1/4 inch
Oil eye thread size: 1 inch
1x Alphacool expansion tank individually for DC-LT pumps
1x sealing ring
1x oil eye with O-ring
4 mounting screws
This product was tested for you:
Hardwaremax
Review Center
Note: Only one of the two inlet openings is required to operate the lid. It is therefore advisable to order a screw plug for this purpose.
Alphacool DC-LT acrylic attachment
€24.98 *
€1.78 *
Delivery date: in 2 - 3 weeks
Alphacool stand for ice blanket/ice cup series - black
8%
and Conditions Alphacool Eisstation DC-LT - Solo Top
€26.98 *
Alphacool Apex 2 Thermal grease 2g
Content 2 Gramm (€4,990.00 * / 1000 Gramm)
