Alphacool NexXxoS HPE-30 Full Copper 240mm Radiator
- Article no.: 14376
- EAN: 4250197143769
- Weight: 0,732 kg
Connection options & mounting
Safety first
Patented screw plugs
| Technical data | |
| L x W x H | 271.5 x 124 x 30 mm (±3 %) |
| Quantity of cooling channels | 14 |
| Material threads | brass |
| Threads | 4x G 1/4 IN/OUT & 1x Fill-/Drainport G 1/4 (max. 5 mm thread length) |
| Possible fan size | 120 mm |
| Possible fan assembly | 2x one-sided / 4x both-sided |
| Pressure tested | 0.8 bar |
| Fin density | 18 FPI |
| Weight | 601 g |
| Color | black |
Warranty: 10 years
