Alphacool Core Geforce RTX 5090 Solid + AMP with backplate
- Article no.: 14730
- EAN: 4250197147309
- Weight: 1,88 kg
- Zotac Gaming GeForce RTX™ 5090 AMP Extreme Infinity (ZT-B50900B-10P)
- Zotac Gaming GeForce RTX™ 5090 Solid (ZT-B50900D-10P)
- Zotac Gaming GeForce RTX™ 5090 Solid OC (ZT-B50900J-10P)
Technical data cooler | |
Dimensions total (L x W x H) | 234,00 x 150,53 x 34,10mm |
Material cooler top | Acrylic |
Material terminal | Acetal |
Material Connection thread | Brass |
Pressure tested | 0,8 bar |
Threads | 4 x G1/4" |
Thickness cooler bottom | 3,25mm |
Illumination | digital aRGB LEDs |
Number of digital aRGB LEDs | 11 |
Color | transparent |
Technical data backplate | |
Dimensions (L x W x H) | 234,00 x 122,00 x 6mm |
Thick backplate without spacers | 3mm |
Material | Aluminium |
Material base plate: | Aluminum |
Dimensions: | 234.00 x 150.53 x 34.10mm |
Connection: | 4x G1/4" |
Hardware manufacturers: | NVIDIA |
Hardware model: | RTX 5090 |
Liefertermin: in 7 - 8 Wochen
Liefertermin: in 2 - 3 Wochen
