Alphacool Apex thermal pad Soft 18W/mk 120x20x0.5mm
  • 13487
  • 4250197134873
  • 0,018 kg
€21.98 *
Content: 24 cm² (€0.92 * / 1 cm²)
€4.28*
€69.98*
WÄM Alphacool Apex thermal pad Soft 18W/mk 100x100x0.5mm
€59.98*
WÄM Alphacool Apex thermal pad Soft 18W/mk 120x20x1mm
€39.98*
Alphacool offers a wide range of thermal pads for effective heat dissipation of electric... more
Powerful!
Increased lifespan!
Versatile!
Technical data thermal pad
Dimensions (L x W x H)120 x 20 x 0,5mm
Thermal Conductivity (ASTM D5470)17.8 W/mK (±10%)
Hardness (ASTM D2240)65 (Shore 00) (±5)
Working temperature-50 to ~150°C
Volume Resistance (ASTM D257)6×10¹² Ohm-m
Dielectric Breakdown Voltage (ASTM D149)4 KV/mm (±10%)
Density (ASTM D792)3.5 g/cm³ (±10%)
Elongation (ASTM D412)20%
Flame Rating (UL 94)V-0
Colorlight grey
€0.98 *
€1.19 *
€6.99 *
WÄM Alphacool Apex Wärmeleitpad Soft 18W/mk 120x20x1mm
Content 24 cm² (€1.67 * / 1 cm²)
€39.98 *
Alphacool Apex thermal pad Soft 18W/mk 120x20x1.5mm
Content 24 cm² (€2.08 * / 1 cm²)
€49.98 *
Alphacool Core thermal pad Soft 9W/mk 40x40x2mm
Content 16 cm² (€0.62 * / 1 cm²)
Alphacool Core thermal pad Soft 9W/mk 40x40x1.5mm
Content 16 cm² (€0.50 * / 1 cm²)
Alphacool fan cable 4-pin to 4-pin extension 30cm
€2.28 *
€34.98 *
Alphacool Eiszapfen 16/10mm screw-on nozzle 90° rotatable G1/4 - 4pcs Set Chrome
€33.98 *
€1.89 *
WAH Alphacool HDX Apex Acetal M.2 2280 SSD Kühler
Alphacool HDX Apex Acetal M.2 2280 SSD Cooler
€34.98 *
Delivery date: in 2 - 3 weeks
33%
€5.99 * €8.98 *
21%
€33.97 * €42.98 *
Alphacool EPDM Tube 16/10 - Black 3m (9.84ft) Retailbox
Alphacool hose AlphaTube HF 16/10 (3/8"ID) - UV White 3m (9.8ft) Retailbox 300cm
Alphacool GPU RAM Copper Heatsinks 6.5x6.5mm - 10 pcs.
Content 10 Stück (€1.00 * / 1 Stück)
€10.98 *
