Alphacool Core Geforce RTX 5090 ROG Astral with backplate
- Article no.: 10270
- EAN: 4250197102704
- Weight: 2 kg
- Asus ROG Astral GeForce RTX™ 5090 32GB GDDR7 (90YV0LW1-M0NA00)
- Asus ROG Astral GeForce RTX™ 5090 32GB GDDR7 OC Edition (90YV0LW0-M0NA00)
- Asus ROG Astral LC GeForce RTX™ 5090 32GB GDDR7 (90YV0LW3-M0NA00)
- Asus ROG Astral LC GeForce RTX™ 5090 32GB GDDR7 OC Edition (90YV0LW2-M0NA00)
Technical data cooler | |
Dimensions total (L x W x H) | 260,25 x 160,90 x 34,32mm |
Material cooler top | Acrylic |
Material terminal | Nylon |
Material Connection thread | Brass |
Pressure tested | 0,8 bar |
Threads | 4 x G1/4" |
Thickness cooler bottom | 3,25mm |
Illumination | digital aRGB LEDs |
Number of digital aRGB LEDs | 12 |
Color | transparent |
Technical data backplate | |
Dimensions (L x W x H) | 260,25 x 132,50 x 6mm |
Thick backplate without spacers | 3mm |
Material | Aluminium |
Manufacturer: | Alphacool |
Material base plate: | Aluminum |
Dimensions: | 260.25 x 160.90 x 34.32mm |
Connection: | 4x G1/4" |
Hardware manufacturers: | NVIDIA |
Hardware model: | RTX 5090 |
Liefertermin: in 10 - 11 Wochen
Liefertermin: in 6 - 7 Wochen
