Alphacool Core 140mm Reservoir with VPP/D5 Apex PWM Pump
  • 13889
  • 4250197138895
  • 1,34 kg
€169.98 *
€18.98*
LED Alphacool Aurora Eiscontrol Addressable RGB Controller - Black
€15.98*
€36.99*
L12 Alphacool Apex Stealth Metal Power Fan 3000rpm Matt Black (120x120x25mm)
€21.98*
The Alphacool Core Reservoir not only looks sleek with its aRGB lighting, but can also be used... more
The Alphacool Core Reservoir not only looks sleek with its aRGB lighting, but can also be used flexibly thanks to its compact size. The reservoir is made entirely of acrylic. The installation of a D5 or VPP pump is required for operation. Due to its compact design, the Core Reservior also fits into small cases.
Core Design
A key element of Alphacool's Core Design series are the chrome-plated G1/4" connections made of brass. In the Core Reservoir, the connections are recessed rather than screwed into a thread, bypassing the problem of possible leaks due to cracking from the direct screwing of the connections into the acrylic. The connections are in two parts, fitted with an O-ring and counter each other when mounted in the acrylic. This not only ensures absolute sealing of each connection, but also allows for the clear and functional appearance of the Alphacool Core Design series.
Easy installation
With the included Core Push Mounting kit, the Core Reservoir can be mounted on the case or on a radiator. The metal pins are attached to the radiator or case panel and the matching female sleeves are attached to the Reservoir (see manual). In the next installation step, the Reservoir is simply and tool-free pushed onto the pins. Alphacool's Push-Mounting allows for a secure fit of the reservoir on the case panel or on the radiator and allows for easy disassembly for maintenance or expansion projects.
Gamechanger
The Core Reservior is small and compact. This makes the reservoir ideal for custom water loops. An additional drain port is located on the side, allowing for easy and uncomplicated draining of the Reservoir.
High-quality material selection & brilliant lighting
Alphacool's Core Reservoir is made of high-quality acrylic glass, allowing for an unobstructed view of the coolant and brilliant illumination by the built-in digital addressable aRGB LEDs. The lighting can be controlled via a digital aRGB header on the motherboard or optionally through Alphacool's Aurora Eiscontrol aRGB controller (item number: 15360).
Dimensions (L x W x H)140.00 x 145.00 x 62.00mm
Volume (reservoir)approx. 130ml
MaterialAcryl
Pump compatibilityD5/VPP
Threads3x G1/4“ inner thread / 1x drain port
Pressure tested0.8 Bar
Quantity digital aRGB LEDs5
Voltage digital aRGB LEDs5V
Power connection digital aRGB LEDs3-Pin JST + 3-Pin 5V
Weight1120g
Colortransparent
Technical data pump
Material pump coveraluminium
Material axleceramics
Connections4-Pin PWM | SATA
Cable lengths4-Pin PWM - 48cm | SATA - 48cm
Starting voltage12V DC
Maximum pumping head4,25m
Maximum flow rate340L/h
Color: transparent;
Material: Acryl;
Dimensions: 140.00 x 145.00 x 62.00mm
Connection: G1/4" internal thread
Pump pre-installed: Yes
Pump compatibility: For 1x D5
Volume: 130ml
WAC Alphacool Apex 1 CPU Kühler AM5
Alphacool Apex 1 CPU cooler AM5
€169.98 *
Delivery date: in 2 - 3 weeks
€34.98 *
Delivery date: in 6 - 7 weeks
Alphacool Core 1 Aurora Black
€119.98 *
Delivery date: in 8 - 9 days
WAK Alphacool Core Geforce RTX 5090 ROG Astral mit Backplate
Alphacool Core Geforce RTX 5090 ROG Astral with backplate
€199.98 *
Content 6 Stück (€2.66 * / 1 Stück)
RAD Alphacool NexXxoS ST30 Full Copper 420mm Radiator
€85.98 *
WAC Alphacool Core 1 LT Black
€74.98 *
WAC Alphacool Core 1 White
€109.98 *
Alphacool Y-Splitter 4-Pin to 3x 4-Pin PWM 30cm
€3.47 *
Content 4 Stück (€4.00 * / 1 Stück)
Alphacool Eiszapfen 13/10mm screw-on nozzle G1/4 - White Sixpack
€6.28 *
Alphacool EPDM Tube 16/10 - Black 3m (9.84ft) Retailbox
RAD Alphacool NexXxoS HPE-45 Full Copper 420mm Radiator
€139.98 *
RAD Alphacool NexXxoS HPE-45 Full Copper 360mm Radiator
€109.98 *
€21.98 *
