Alphacool Core Geforce RTX 5070 Reference with Backplate
- Article no.: 10271
- EAN: 4250197102711
- Weight: 1,216 kg
*1Alphacool introduces its new series of graphics card water coolers for the latest Nvidia GeForce RTX generation. Part of the Core product series, these coolers combine the highest quality with exceptional performance. Thanks to an optimized technical design, these GPU coolers deliver outstanding cooling performance.
- Inno3D GeForce RTX™ 5070 TWIN X2 (N50702-12D7-195064N)
- Inno3D GeForce RTX™ 5070 TWIN X2 OC (N50702-12D7X-195064N)
- Inno3D GeForce RTX™ 5070 TWIN X2 OC WHITE (N50702-12D7X-195064W)
- Inno3D GeForce RTX™ 5070 X3 OC (N50703-12D7X-195064L)
- MSI GeForce RTX™ 5070 12G INSPIRE 3X OC (G5070-12I3C)
- MSI GeForce RTX™ 5070 12G SHADOW 2X OC (G5070-V532 V1.1)
- MSI GeForce RTX™ 5070 12G VENTUS 2X OC (G5070-12V2C)
| Technical data cooler | |
| Dimensions total (L x W x H) | 149,00 x 124,07 x 34,12mm |
| Material terminal | Nylon |
| Pressure tested | 0,8 bar |
| Threads | 4 x G1/4" |
| Number of digital aRGB LEDs | 6 |
| Color | transparent |
| Dimensions (L x W x H) | 149,00 x 95,50 x 6,00mm |
| Thickness backplate without spacers | 3mm |
| Material | Aluminium |
